Rodent in the engine
the problem with using poisons is that they can die inside your car somewhere. Door panels, headliner, etc. Only traps should be used for vehicles, along with a defensive approach at the same time.
This. Poison seems the easy way, but it's a really bad idea. As said, they just crawl inside somewhere to die.... and you really don't want that to happen. Spring traps + peanut butter FTW.
I had what appeared to be mice set up residence in my in cabin air filter compartment. I couldn't figure out why I kept having leaves in my glove box. When I went to clean my air filter apparently the mice is set up quite a nice home there. It appears they took part of the firewall felt to use as a blanket they had ketchup packets which were empty, apparently that was dinner.
Mice can squeeze down to a very small size and find your way in almost anywhere. My parents had a whole bunch of mice living in their motorhome and they had to have everything rewired.
I was lucky I didn't have any damage. Apparently the mice were just looking for a place to get out of the cold.
My parents told me about an all natural repellent for rodents. It is called Fresh Cab. I placed two packages in my 4Runner ...one in the area under the hood where it appears that they got in and the other I placed in the compartment in the rear of where I store my Jack. This solved my problem very quickly.
If you live in an area that has a whole lot of rodents you can also get devices that mount under your hood that emit a noise that the rodents don't like. My parents use these as well as the Fresh cab in order to protect all their vehicles. They do live out in the country.
I hope this helps. At least you wouldn't have to worry about a mouse dying somewhere in your car. That would be a nightmare. The Fresh cab just keeps them away and if they're there it runs them off they don't like the smell.
Sent from my motorola one 5G UW using Tapatalk
sorry to hear that happened... I am also dealing with a rabbit which chewed up some wiring of my toyota FRS =(
A RABBIT!! :suspicious:
That's one I have never heard of before, what makes you so sure it was a rabbit that chewed your wires, rabbits aren't known for chewing on wires??
