Lift and Tire Central (pics)... Post 'em Up!
hammersc
So many great pictures of leveling kits, lifts and aftermarket tire combos scattered all over this site - let's get them all in one thread.
Got a lift and/or aftermarket tires?
Post pics and short description!
1. Lift brand & size/style
2. Tire brand & size
3. Like the results? or Would you do anything different?
Show me your lifts!!!
This is a great idea. So many people want upgrade tires or add a lift that we have many repeat threads that request pics/info about tires and lifts. This thread is now a sticky to help people get an idea of what might be right for them
If you have a lift and/or upsized tires please do as HammerSC suggests above and feel free to add a link with more details of your lift. If you have a specific question search, search using the Google trick here and finally, if that fails, start a new thread.
To those shopping for lifts, skim the T4R of the month. If you scan through the current and past T4R of the month thread the lift/tire combo is usually mentioned.
The goal will be to have work like the DIY mod sticky in the General Section. Thanks for participating:bigok:
Chris (aka CJ3Flyr)
FYI- I have and will periodically go through this thread and delete some posts. I am deleting the posts that are text only and conversational in nature. I'm trying to keep this as a pure and clean lift/tire pic thread.
I'm not discouraging 'conversation'. I'm just going to clean it out after it's a week or two old...:D
Chris
-3" Toytec Spacer lift
-275/70R17 Goodyear Wrangler MT/R with Kevlar
-LOVE IT! I most likely will upgrade to adjustable coils in the future but for the money this thing rides wonderfully
SpringCreek.jpg~original
FJ Cruiser Offroad edtion coils and shocks(silver Bilstein). BFG A/T KO 265/75/16
cost: $100 for everything, include the complete assembled front strut assembly.
3/4" front, 1" rear. firmer ride, cheap and effective, done by 3 hours by myself in the drive way with simple tools.
IMG_0163.jpg~original
FJC front shock assembly(silver) vs. stock SR5 (black): coils have same amount of wraps, but FJC coil has thicker wire.
IMG_0060.jpg~original
FJC rear coils have 1 extra wrap, also thicker wire, but same length as stock SR5 4Runner unloaded.
2.5 Fox Coilovers now installed
17" X 9" Pro Comp 7105's with -6mm offset and 305-65-17 Mickey Thompson Baja ATZ's
1.5" RB Bodylift
Love it!!!
Simple 1.25" front level kit, Cornfed (5/8" spacer)
265/70 Destination ATs
Toytec Ultimate 3" lift Nitto Terra Grapplers 265/70R17s with Spidertrax 1.25 spacers.
Love it.
Just converted from the Cornfed 1" Front Leveling Kit with stock Limited tires (265/60/18) to the Cornfed 3/2 Lift. Spidertrax wheel spacers, Michelin LTX A/T2 275/65/18 with XREAS preserved. There was no rubbing with these tires until I got the front end aligned. Now I've got a slight rub at the rear of the tire on the frame when cranked all the way. This weekend I'm going to try to adjust the camber a bit to move the wheel forward just a bit. If that works I'll be in heaven as I love the way it looks and drives. If that doesn't work, I am not sure what I will do. I cannot live with the tires rubbing since my son and I do some light offroading.
IMG_1931.jpg~original
IMG_1932.jpg~original
Cornfed 2/2
BFG 265/70/17
Spidertrax 1.25 Spacers
Very happy with all of it!
<img src="http://home.comcast.net/~imacrick/T4R/2.jpg"/>
I have stock Michelin CT's (265/65/17), FJCruiser springs in all 4 corners and 3/4" net lift Cornfed spacers in the front.Links with more info in my sig.
:cheers:
ATLSept08b.jpg~original
frontsmall.jpg~original
rearsmall.jpg~original
I've added 255/75/17 Goodyear Wrangler Silent Armours. No rubbing, no issues, 35psi front, 33psi rear is awesome, mpg is up, mpg meter is dead-on, stock rims, no spacers. Tire link in sig.
Dirty1s.jpg~original
GYSAs5-1.jpg~original
SAS in progress, Diamond Axles, Fox Coilovers in the Front...will be running on ProComp 37" X-terrains when completed. 1.5" Body Lift + ??
DSC01728.jpg~original
DSC01729.jpg~original
DSC01730.jpg~original
DSC01731.jpg~original
DSC01732.jpg~original
DSC01734.jpg~original
DSC01724.jpg~original
DSC01725.jpg~original
DSC01727.jpg~original
DSC01736.jpg~original
DSC01735.jpg~original
[/QUOTE]
cornfed 3/2
spidertracks on the rear (fronts rub on the body mounts when installed. once i get the body mounts chopped i should be able to run them)
FJ cruiser wheels 17x7"
295/70/17 nitto terra grabbers
love the ride. same as stock. road noise is minimal.
rear mud flaps have since been removed as they were quite close to the tread on the tires.
i tow with it and the setup works great. not a problem at all. super firm and doesn't rock or sway or float at all with 4000lbs or so behind it.
Picture017.jpg~original
Picture011.jpg~original
Picture010.jpg~original
Picture009.jpg~original
Picture012.jpg~original
Picture008.jpg~original
Getting my Daystar Front leveling kit installed this Saturday and hopefully some new 265-70R17 Mickey Thompson MTZ tires as well. :D
1. Lift brand & size/style - Daystar Leveling Kit
2. Tire brand & size - OEM Dunlops 265-65R17
After!
good idea
04 4Runner ADV Edition.
I run 3 inch OME hd springs and a bit of coil spacer out back. The LC4e is 280lb's bike and the rig sits about level.
Here's my 2003 T4R Sport.
- ToyTec Ultimate 3" Lift
- Cooper Discoverer S/T 275/70/17
- SpiderTrax 1.25" Wheel Spacers
- Kenwood D710A with Diamond Tri-Band antenna on a Diamond Lip mount for APRS
03T4rSport1ToyTec.jpg~original
03T4rSport2ToyTec.jpg~original
03T4rSport3ToyTec.jpg~original
03T4rSport4ToyTec.jpg~original
brushbuny
