01 Gauge cluster led's help request
I want to replace my gauge cluster lights with LED's, what kind of led's do I need?
3 24's for cluster
all the little ones are 74. key ring, 74.
there are a lot of posts on this. it took me a while to find what i wanted but this is the end result. the a/c control uses 3 neo4 and the back window/ect uses 2 neo3. i had white for the key ring, but red gives it more flavor. these pics don't do the lights justice. they are brighter.
thanks my man, I wasnt looking hard enough you were talking about #24 on the list of them correct?
the bulb number is 24, for the cluster, 3 ea. there is a crap load of 74's that light up all the other lights. you can change them too if you want. i chose not to.
The search feature is your friend.
Sorry bub this is round two for me, went off what I found here last time I tried to do this, sold them to another budy on here for his early 3rd gen cause they were the incorrect bulb for my later 3rdgen :yo:
It has been documented 100's of times what bulbs each year takes.
[MENTION=96863]01thunder[/MENTION] I did the gauge cluster last night, just for the information, the gear shifter nor the a/c control took the 74 bulbs, I'm gonna have to figure out what kind of bulbs they take and order some new ones.
For the a/c control unit the bulbs were wired through the fitment so I'm not sure how I'm gonna get that one figured out. [MENTION=94929]Taylor20[/MENTION] maybe I'll use the search tool :shrug:
For the A/C, see the bolded part in 01's post.
And here is a good post for you to check out: http://www.toyota-4runner.org/3rd-gen-t4rs/78310-led-conversion-questions-2.html#post870257
Might try a #194. In Ripcord's chart, it says that's the one you want for the 2wd on the 96-00, but maybe it's the correct one for all years on 2wd models.
WLED Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs Look for the ones that are #194s. Again, I'm not sure if those will work (I don't even have an automatic), it's just a hunch.
Also, you should post up some pictures of your gauges. I just did the swap last night, and the #24s I got aren't nearly bright enough, so I'm thinking about doing them again with different leds. I'm curious to see what yours looks like.
Theres some hot spots I know, I have to get back in there and wax paper that stuff
