03 4Runner Instrument Panel Failure
ahriman
Hello All- First post, just joined. I usually spend time at either Yotatech or Pirate. Hopefully you may have some insights on this issue whereas neither of them did.
A couple days back I was approaching a stop light and lost my speedo. The idiot lights all lit up (check engine, vsc track, ABS etc.), and since then I have noticed the fuel gauge is not accurate and none of the odometers are incrementing. The cruise control indicator lights, but cruise control will not engage. Another symptom: the fuel range indicator above the heater controls counted down to 0, but after a fillup did not reset. The tach and temp gauge are fine. I checked fuses and nothing appears blown. Any ideas? 2003 4Runner, V8 SR5.
Thanx, look forward to wastin ... er, spending time on another forum.
Waste time? Yeah, me too, LOL
Welcome! Have you check the connectors behind the cluster? There are two of them, one of them could be loose (they screw on to be tightened). If everything else checks out, try these guys:
Speedometer Repair | Speedometer Not Working | MyAirbags
