04 Headlamp Wiring Colors -which one is Hot/Ground
natevans65
Two wires......Red with Green and Red with Blue for the main headlamp. The Hanyes manual does not address colors and I need to splice into the Hot and Ground but not sure which is which? HELP! and as always.....thank you for your help!
if the plug is still there, usually the left is ground and the right is hot, meaning its reverse. not ddm to use to test to make sure?
So you are saying if seated in the drivers seat and the plug is plugged in.....left is ground....right would be hot if looking forward. I do have a tester I can use to see what is what, just need to find it. Thanks!
I used my tester and found the hot wire! Why do I make is so dern difficult!
