05 4Runner head unit replacement
Hocecoach
Just bought an 05 and the first thing I did was pull out the original head unit and speakers and replaced them. Everything went fine, except...
The original unit has two antenna leads - one is smaller than normal. The new head unit can only take one, so I plugged in the one that fit. Now I get crappy reception on the radio. It seems that this is an amplified antenna system??? How can I incorporate this on my Pioneer head unit?
you need a Y splitter
and adapter then plug this into the antenna jack on the aftermarket HU.Here are links to the parts.
Y-adapter: Amazon.com: METRA Ltd 40-UV43 Motorola Antenna Y-adapter: Electronics
Size adapter: Amazon.com: Scosche Mda-B Micro/Delco Antenna Adapter Tip: Electronics
05 Stereo Heat Unit Issue
Actually, the problem with my new head unit had to do with the fact that I didn't realize I had to connect the power antenna wire. Apparently, 05 4Runner's have an antenna amplifier!
Giordano Schoenwetter
