06-09 LED headlight bulbs. MUST TRY list
Light output is FAR better than 35w 6k morimotos. Others in this thread have also verified this. The pics on the front page demonstrating beam and cut off are accurate. Make sure you are using them in 06+ headlights with the projectors and that the headlights are properly aimed. No way I would spend the money for HID’s. Even my 3rd gen is rocking custom LED retrofit headlights now, (no projectors in the 3rd gen headlights which need to be retrofitted to run these or comparable LED bulbs).
I've had these installed for probably a year now. And while I like them for city driving, they barely throw any light past 150ft or so. Highway driving at night feels borderline unsafe at 70mph. I'm wondering if it is due to the 6500k color?
I find it hard to believe that these beat out Morimoto HIDs... but what temp were your HIDs that these beat out??
Again though, the Auxbeams are great upgrades for the cost... assuming you only drive in the city.
At that temp, you need to go LED or HID...there are probably halogens out there that can 'simulate' the color, but the light output would leave a lot to be desired.
On a side note, I went with these on my '05...
Boslla Bullet B4 9006/HB4 - The World's first 4 Color LED Headlight - Boslla
The white mode is 'ok', but the mix and yellow (especially in rain) mode...damn, I can see!. The white mode (mode 1) is too much like a high beam. Would like to go with another set of these for the fogs, but worried about exposure.
Any update on these? Still liking them?
I've read through most of this thread and I really want to upgrade my headlights. I'm debating replacing the projector housing on my 06. The driver's side has condensation and both sides are yellowing. I like the oem look I don't know if I want blacked out housings yet. With that said has anyone gotten the projector housings from rockauto? Wondering how reliable they are. Also any updates on the DTR leds? Seems hit or miss, thanks!
I have an '08 with projectors (and yes, properly aimed). Though it is aftermarket housing.
So I caved and bought Morimoto HIDs (35w, 5.5k). The light THROW is almost double that of the Auxbeam LEDs. At the end of my block is a house that the LEDs would barely touch. With HIDs, there is a clean, crisp beam pattern ON their house now. Even for the cost difference, I would buy HIDs again because I can finally see at night again.
Now it appears BXbuilt has LED specific projectors. So that probably makes a difference. And its possible that my aftermarket headlights (with projectors) aren't suited for LED, but again, in my situation, the HIDs win hands down and its not even close.
Glad you’re happy with the HID’s. Not a route I will ever take again.
I must admit I was skeptical that LED lights could provide enough light output. I was wrong.
Ended up going with Beamtech H11 bulbs with a fanless heatsink design. For $30 on Amazon it was money well spent.
It’s a clear, but not earth shattering, upgrade over the stock halogens. Wish I had installed them sooner
I’ve had them for a year now, and now I get all the error codes on the dash. Still working fine...
Do I try adding the resistor kits to make my truck happy, or time to ditch ‘em?
Adding another data point here - I put Auxbeams in my 2006 May 1, 2019, and my passenger side started flickering last night. Going to review the current LED market and make another purchase, if its Auxbeam great, if I find something else I'll give them a shot.
Can't use these bulbs since I have these headlights!
06-09 4runner headlight bulb number & led upgrade
2006 - 2009 Toyota 4Runner Low Beam Headlight H11
Boslla Bullet B4 H11 H8 H9 LED Headlight Bulb Fog Light Bulb - The World's First 4 Color LED Headlight
2006 - 2009 Toyota 4Runner High Beam Headlight 9005
Boslla Bullet B4 9005/HB3 LED Headlight Bulb - The World's First 4 Color LED Headlight
2006 - 2009 Toyota 4Runner Front Fog Light 9006
Boslla Bullet B4 9006/HB4 LED Headlight Bulb - The World's First 4 Color LED Headlight
Driving visibility has been greatly improved after installing the Boslla B4 led headlight bulbs. They have 6500k/4300k/3000k three color temperatures, work perfectly for rainy, snowy, foggy, and more extreme weather conditions.
Boslla B4 4-In-1 LED Headlight/Fog Light Bulb - 6500k
Boslla B4 4-In-1 LED Headlight/Fog Light Bulb - 4300k
Boslla B4 4-In-1 LED Headlight/Fog Light Bulb - 3000k
Looks interesting.
Can you provide LUX reading and photos of the cutoff in our trucks?
I used some LED in my Fogs, and the cutoff was non-existent, and blinding to other drivers so I switched back to halogens... and I had LEDs in the high beams as well, and the beam was unfocused and there was loads of foreground light, but very little was being thrown down the road where it's needed most. Had to switch back to Halogens as well.
Squirrel finders for 4th Gen HID Upgrade
Hello guys, my HID bulbs are arriving today for upgrading my 08's low beam headlights. I'm excited for the upgrade, but found few posts about adjusting tabs inside the 4th gen projector headlight housing to remove "squirrel finder" boxes above cutoff line to eliminate flare. But, I cannot seem to find any pictures showing what actually to adjust. Can someone post pictures or a link to a post please?
Looks interesting.
Hello
Here is an honest full review about our bulbs from BulbFacts, please feel free to check it out and reach out to us for any questions.
BulbFacts | Boslla Bullet 4-Mode LED Headlight Kit Review
MaximussK
