1.25 wheel adapters 2 with all hardware
These came off a 2005 4runner
These were used for almost a month...I do not need them!
They come with all mounting hardware
6x5.5 to 6x5.5
1.25 think
2 only
$50 dollars shipped
KGrHqRHJCEE63URhzdBO09Weesg60_35.jpg~original
Are those the actual picture of them? So they aren't hubcentric?
No that is not the pic of them, they look identical~ Not sure what you mean by hubcentric?
4th gen 4runners rotors rest on hub studs!!! Not a centric hub~
1.25 will be the smallest adapter you can get that will allow the factory studs to be flush with the adapter. Unless you have a wheel that allows the studs to pass.
Hubcentric have a chamfered lip extends from the spacer that fits inside the lip of the hub hole in the wheel. The picture shows a lug centric spacer.
That is correct.
Not to be used with hub-centric factory Toyota rims. All other rims should be fine, ymmv.
