1.5" Ebay wheel spacers
black_120
Set of 4 1.5" wheel spacers. The spacers are made of biliet aluminum and are hub centric, but do not have a centering ring. A little too wide for my t4r since im only lifted 1.75". Also I only have 12 lugs but they can be found at discount tire.
$50 + shipping.
I bought them from lugman and used them on my dad's sequoia for 2 years with no issues. wheel adapters
Forgive me fellas, but i lied. It actually measured out to 1 3/8" spacers. Whatever lugs i have will be included.
Help me understand how hub centric works without the ring in the center. Sorry I'm a weekend warrior and not a genius like most of the people on here.
Basically the center ring helps you line the lug nuts up and make sure the wheel is centered exactly. You can still center the wheel without the ring, you just have to center your wheels carefully when bolting them on.
These are not hub centric as they do not have a ring to center the wheel. A hub centric spacer will have a ledge to set the wheel on just like the actual hub.
And that can cause vibration or shaking issues in the front correct?
It can cause vibrations if you dont center the wheels. Same thing if you are running aftermarket wheels without a centering ring. The only true hub centric spacers i've seen are the H&R and Spidertrax which have a lip on the center of the spacer.
I run a set just like this (from Allpro Offroad) without any issues. No vibrations if you put them on correctly...
Good price for a set of spacers. GLWS
Daniel Frost
