nightshade000
If space is a concern, switch out for one 12 (or even one 8, if you're not looking to be heard a block away -- literally). two 10's will have more 'punch' because they're moving more air @ the same frequency as each other than a single 12" can. A 12 can produce lower frequency sound, but honestly, unless you're doing competitions, or listen specifically to special bass CD's, you probably won't notice a difference in the frequency response. Conversely, a 10 will be able to produce slightly higher frequencies, that you are really quite likely to be able notice more.
In practice though, 90% of the people in the world, can't tell the difference between frequency response between a good 10, and an equally good 12. You'll feel two 10's more than one 12, but any sub of sufficient quality is capable of literally shaking your car apart. Not to the point of breaking down, of course, but it can back some screw out. A friend of mine has an eclipse that's going on 10 years old and the dash vents under the window are very brittle. His subs have broken a few of those and made the fall out.
My opinion is, if space is worth more to you than a couple hundred, get the 12. If you'd rather save the couple hundred, keep the two 10's. Of course, that's assuming you already have an amp capable of driving them.
