12VDC Outlet
TomW'ski
Finally got around to installing a 12 volt outlet that is not switched off with the ignition. Not an overly complicated job but took 2+ hours since I needed to be careful with the plastic parts in the console.
1. had a 12 volt socket scavanged from a bad battery power pack.
2. pulled console "gently" up and back after removing transfer case knob and putting shifter in neutral. No need to unhook wiring.
3. used red and black #16 wire taped into a side by side line that I fed through the rubber grommet where the AC passes through the firewall. This comes in just above the gas pedal.
4. pulled off the driver's side panel just right of the pedal in front of the console, not absolutely necessary but curious and made passing the wires into the console easier.
5. drilled a hole into the passenger side of the console and installed the socket. A bit of a pain as there is a bundle of wires right there that I had to forcibly pull out of the way.
6. put disconnects on both wires where they join the socket.
7. in the engine compartment, ran the wires along the main wiring harness going to the fuse box, fastened with cable ties. Connected the black (ground) wire using a crimp on eye to the ground strap bolted to the body next to the battery.
8. put an inline mini fuse holder on the red line with butt connecters and then put a crimp on eye and fastened that to the positive battery cable. Fuse/hot line runs between the battery and the fuse box, easy access and out of the way. Currently using a 10Amp fuse. Note: when buying fuse holder get one that holds the mini fuses that Toyota uses then you won't need to carry different extras.
9. checked circuit out and reinstalled all panels. Works great.
Incidentally, I chose the side of the console as it was the easiest spot to work with since there was room beside the transfer case shifter. I would have preferred the side of the dash but didn't want to remove any more panels then necessary, sooner or later something breaks. Also used heat shrink tubing on all the electrical connections (love that stuff!)
Pictures in album file under 12Volt outlet
I am looking at a similar mod. Did you look at putting the 12V in the center console?
There appears to be sufficient room adjacent to the AC power.
Atomic: Firstly, on my 2010 I don't have an AC outlet in the console. Beneath the radio I have a DC outlet that is ignition controlled, and a socket to connect my IPod, all the rest is storage compartments.
Secondly, I don't like taking too many plastic parts apart because sooner or later I will break something. I had considered just rewiring the existing DC socket but then I would only have the one so since I had the parts and the time I went for the mod I did. I posted my mod just to put some ideas out there since we all hate the switched socket.
I will be installing a similar mod this week and have a few questions:
1) If I elect to pull power from the fusebox inside the cabin, can I put the add-a-fuse on fuse #27 (Towing bkup) and achieve constant on? This is a 10A fuse, but I have not tested it to find out if it is constantly on yet.
2) If the towing bkup isn't a good fuse for this purpose, is there another fuse in the interior that is constant-on and safe to tap? The fog lights is the only other one that looks "safe" to me...don't want to screw with the important stuff!
3) To the OP, which fuse did you tap in the exterior fuse box? I was thinking of wiring into that fusebox to install lights under the hood as Harper7 did.
Thanks to all - I've done lots of searching and seen lots of great ideas, but somehow I haven't seen the exact fuse recommendations.
ian2328
