1990 Dash indicator lights intermittent
brettniles
A while back I noticed I started losing dash indicator lights. First it was the high beam light, discovered after realizing I drove back from a trip blinding ppl the whole time. Then it was my 4wd light was finnicky then gone. Got into the dash with some new LEDs, tested them all and figured out the correct polarity. Now, after putting it back together even more of them (seat belt, brake, etc.) are out. Cluster LEDs work fine. Just the indicators are out. Shop tested the cluster for continuity and that is good. Where should I be looking next?
Bulb holders making contact with circuit board? Broken contact at connector? May have to pin check power.
erinobr2000
