1999 - fuel gauge problem
I also know this is an old post but I need help.
I just purchased a 99 SR5 and the gas gauge goes to full as soon as it is started, I can back up or just let it sit and idle and needle stays on full.
If I start going forward, most times the gauge drops instantly to empty and the fuel light flashes. Sometimes I can go a few hundred yards before it drops to E and the light flashes. If I shut it off turn the key back to on or start it the gauge instantly goes to full.
I have searched the web high and low and this is the closest post I can find to my Runners problem.
I checked tail lights and ground behind LH panel, and all is fine.
Did any of you members with this problem end up fixing yours?
Thanks JROTN
Hey man,
Try performing this instructions... (if that doesnt work, then you will probably need to swap your level sensor that is inside your tank... i would buy a used one from ebay but original toyota, the new one if you have $$$ would be better, but since you are trying to figure it out, a used one will do the trick... but try to do the steps below first.)
DO:
Vehicle has to be sitting on a level surface with an inclination of +/- 0.5 degrees.
1.With the ignition switch in the Off position, press and hold the trip speedometer reset button.
2. Continue pressing the reset button while turning the ignition switch to the On position.
3. Within 5 seconds of turning the ignition switch On, release the trip switch, press trip switch 3 times and on the 3rd press, hold the switch for 5 seconds. The buzzer will sound for 1 second at 800HZ.
4. After the buzzer stops, release the trip switch.
5.Press the trip switch one more time and hold for 5 seconds. Once more the buzzer will sound for 1 second at 800HZ.
Hey man,
Here's my update (and, as always, I will indicate that many people on this forum know much more than I):
I spent this past summer periodically trying to solve my issue (see my previous post on this strand). Unfortunately, the reset instructions above and the level sensor were not my issue, nor my fix. From my internet research, I concluded that there is a relatively rare but occasional occurrence wherein a single incident with the trailer plug or tail lights creates a short in the wiring that for some reason makes the fuel gauge act with the symptoms you're describing. IF you are lucky enough to find the short/fix the grounding issue, the gauge appears to go back to normal. If you can't locate it, you are out of luck. During the summer, I tried to follow wiring diagrams and systematically test every possible wiring route I could get my hands on with my meter and, when possible, checking and tightening any grounds I could get to. I went through everything I could reasonably get to and found no issues, although on a few occasions, when tightening the grounds, I definitely noticed slight changes in the patterns of "misbehavior" of the fuel gauge, making me think I was on the right track. Further, whenever I plug in my camper to the trailer hookup, the fuel gauge works again.
I never solved it, but after a summer of tons of driving and using the trip odometer to estimate refueling, I decided there was no other negative impacts to what was happening. So, when my buddy told me to my face, "Dude, its time to just let it go", I (a) pulled the dashboard (and replaced the dash lights with LEDs while I was in there) and yanked the low fuel light out; and (b) bought and installed the ScanGauge that others recommended. It creates an additional step when fueling up (i.e. inputting the amount of fuel I put in), but I don't even think about it now and actually much prefer now knowing exactly how much fuel is left, particularly on road trips.
So, if you combine all the advise above (and elsewhere) from folks who know much more than me, and my experiences, you may perhaps follow the steps of:
1. Resetting the sensors as indicated above
2. (optional) Replace the level sensor -- if you suspect it may be the culprit, or just want to eliminate it as a possibility
3. Check and potentially replace the tail light bulbs (this worked for at least one other person with the exact same issue...an old bulb was creating a short).
4. Check the grounds on the trailer wiring, tail lights, and perhaps elsewhere.
5. Give up, yank the fuel light out from the dash and install a ScanGauge.
Good luck and let us know if what works, if anything! I know several folks around the web are still searching for the solution to this rare but frustrating mystery!
Thanks Cesarel and SeaBass5000x
I tried the reset procedure tonight but did not work. When I performed the reset procedure the first buzzer sound was correct but the second one sounded like a higher frequency and did not stop buzzing until I shut the key off. I did think about spending the money for new tail light bulbs just to verify nothing was going on with them. I did try running it without any tail light bulbs at all and nothing changed.
Thanks for the help and if and when I find the GREMLIN I will post it for others.
JROTN
JROTN
Good luck amigo! hopefully you will find a solution!
mine is doing this same thing and the tach is jumping too, with the key ON but not running the OD flashes, the tach and fuel gauge jump, on then off in a random interval, anyhelp would be greatly appreciated
WoW!!! Exactly my problem
Nate, this is what happened to me. I connected a trailer and zap! I smelled the burnt wire. I thought the smell came from behind the dashboard. I hope your location is where I have the problem. Easier to get to. I will post my results. Thanks!!!!!!!!!!!!!!!!!
Steve
This happened to me a couple years ago, so bear with me for the lack of specific details I can give...
Mine developed this issue after connecting an improperly wired trailer!
The first time i pressed the brake pedal, it blew the taillight fuse. Replaced the fuse several times, to no avail until I disconnected the trailer plug... All of the sudden my fuel guage would drop to empty after putting the truck in gear and the low fuel warning light would start flashing. This was NOT a fuse issue, but WAS related to my taillights... I was so confused!
I spoke with two Toyota wiring gurus who both said "the fuel guage doesn't share any wiring with the taillights so it couldn't be related"... I was stumped to say the least because this all started after the trailer incident.
One thing lead to another and i decided to dive into it myself knowing they HAD to be related. While inspecting my trailer wiring harness, I noticed the ground wire had gotten hot and the wire was somewhat melted from the inside... I added a larger guage ground wire for my taillight/trailer wiring harness and low and behold, the fuel guage now functions as it should and have had no further issues since that day.
Long story short: Check the chassis grounding point behind the left rear cargo panel (in front of your left taillight) and check for loose connections or possibly a slightly melted wire. Your issue may be farther down the chain somewhere, and could have been pulled loose from the tank/sending unit during the removal process.?.
GOOD LUCK WITH YOUR SEARCH! Feel free to P.M. me if you have specific questions.
Nate
Steve
I am having the exact same issue. Bought a replacement cluster with the correct mileage (expensive). Gauge worked fine until I hooked up my trailer, and no works no more.
Did you ever solve your problem?
Fuel Gauge Not Working
Hopefully someone will come across this post. After replacing my starter, my fuel gauge is doing exactly what everyone here is describing. Shows full, drops to nothing with light blinking, and then back to full after restarting. Has anyone came up with anything on this? I can’t find anything anywhere.
I just recently bought a 99 Limited and the gas gauge would always show empty with the gas light blinking. Last night I added a new ground for the wire and now the gauge just reads full with no gas light. I'm not sure what to do next. Maybe I need to replace the whole gauge cluster? Please help!
Might Have Fixed It!
I have been having this problem for years. In 2017 I posted saying that I thought that I might have had a bad tail or brake light bulb and that it was fixed. It didn't stay fixed very long. I gave up and used mileage to keep up with fuel quantity. Today I noticed that the brake light on the top of the hatchback was out. When I removed the bulb I noticed that the inside of the socket was black and burned on the inside. The socket needs to be replaced. Without the bulb installed the fuel gauge is working perfectly. I have ordered a new socket and will keep you updated as to whether it still keeps working correctly when the new socket is installed with a new bulb. Hopefully the burned socket is what is causing the short.
Similar issue
I’ve got a similar issue with my 99 SR5 - I thought my fuel gauge was busted the day I bought it. Tried to lead a new ground cable for the fuel sensor with no luck.
Just today I picked up a trailer to tow and after connecting the trailer to my rear hookup the fuel gauge started working again… I know this means there are some crossed wires, but I can’t for the life of my figure out where to start when looking for them.
tuṣṭāva
