1st Gen Supercharger nose cone Rebuild and Mod
now I can change the oil anytime I want using a syringe and small tube to suck out the old oil before putting new oil in. A big thanks to my friend Marc for all his work on this project.
Do you put loc tite or anything in the plug?
How is it 2 years later?
Would you have done anything different?
Thanks rockdawg for your tips and advice along the way! Your nose cone rebuild thread was very helpful.
Do you guys have any links to the bearings you bought on ebay?.
I used viton O-rings from McMaster Carr:
I forget what size I used, but if you measure the old ones they'll match up to one of the ones on that page.
May I ask all of you guys' opinions...
I've got a small leak of oil seeping out from behind the pulley where it meets the nose cone. It's a small leak but big enough to notice. Would you think this is due to a failed seal or do you think the supercharger is literally bending apart from the stress of everything?
I would hate to spend the time and money to replace the seal and it still leak :crybaby:
my guess is that your seal has gotten hard over time. these superchargers create A LOT of heat and that is why you should replace it with a good vitron seal that will hold up to the heat better. Unless your shaft was impacted I don't see how it could be bent. Just my .02
the good news is that it is a cheap fix but does take a little time :)
Pics of where the viton seal goes in would be amazeballs.
I don't have a pic but the seal goes in the nose cone behind where the pulley goes on. Vitron is a type of seal that will hold up to heat better. Try to set the seal depth just a little different from where it was before so it rides on a different part of the shaft than before.
ghengiskhan
