2 In 1 Key Fob 4Th Gen
That's the same key fob for the MK5 Volkswagens. I was trying to figure out where I saw one of those before....I had a 2006 Jetta TDI with the exact same key fob (factory).
Sigh... So I have a problem. Turns out the only key I have for my 05 4runner is a gray valet key.
I received my new all in one switchblade style key. I got it cut just fine. I programed the buttons to work just fine. But since I have a valet key, I cannot program the new key to start the vehicle. I called dealer to ask how much it costs to make a new master key and they are around $200. Any suggestions???
Thank you
About $70ish at ACE to get an aftermarket clone of the valet key made, I only had 1 valet key and wanted a backup just in case
Ty brotha! Just ordered.
Wanted to show y'all a side-by-side profile of the 2in1 key fob :doh:
It looks nice, but I'm going to return it. It's bulkier than a 2 piece and the light weight makes it feel cheap. You know what, I'm just gonna give it to my wife. She won't know any better. Puhahaha
Wow it is bulkier, although I’ve never seen a remote fob like yours before. My original one is even smaller and rectangular, instead of triangular like yours. I may just get the aftermarket case someone posted instead of the switchblade key.
Just finished programming and cutting all by my lonesome.
Instructions in this thread are accurate and will help.
I used a roll push pin to take the blank out. It helped a lot at the local hardware store. They couldn't have fit the blank with the fob attached.
Great cheapo mod! Now my wife has a fob and I have a cool key
Sent from my SM-G965U using Tapatalk
Did you get it to roll down the back window at all? Maybe with the trunk button?
Yes the trunk button rolls down the rear window. The only issue i had was the panic was quite easy to accidently hit so I just glued the button on the board so it can't get pushed.
FYI, the same US seller with the new style fob is also selling the VW-style fob for $15.96 + $2.98 shipping:
Upgraded FLIP KEY REMOTE FOR TOYOTA HYQ12BBX DOT CHIP KEYLESS ENTRY ALARM FOB | eBay
Bought this exact VW style FOB from this seller. Came in two business day with the key, fob and 2 roll pins to attach key to the FOB. Program of the FOB and key went smoothly and found a local lock smith to cut it for $3. Only gripe with this FOB is the logo (Wifi K logo), which i'm sure is removable. All in all great for $23 dollars!!
How's the build quality on it? Does it feel light and flimsy or does it have some heft to it?
Any chance you could post a pic of the front. I ask because, based the eBay pictures, it looked slightly different than the other ones posted in this thread.
Still have my original flip key from the beginning of this thread. Still going strong on the original battery, works perfect... - my first post in this thread was Nov. 2016, talk about getting your money's worth. Cheers!
