2 many broke runners build
brifri01
I have purchased all my runners in not running condition and this is the only one I've fixed. It is a 1986 4runner with 22re swapped w series tranny. It originally came from Illinois, land of no inspections. So it's had a hard life came to me from PO as a mud truck. Has hole in the hood from vacuum hose snorkel. I've rebuilt the engine swapped out the auto and utilized the 3.5" body lift with a flat belly. Wheeled the crap out of it accumulated parts to swap in a solid axle. So here it is when I got it.
465_zps4335571a.jpg~original
A more DD status here
IMAG0848.jpg~original
Picked up some very used 37s which rub a lot
null_zpsac393cea.jpg~original
Here is the flat belly shot
null_zpsf4be7d5f.jpg~original
I plan on removing the body lift so there will be lots of floor modifications in its future. But the game plan now is duals, SAS, ruf, 63s, hi steer. Just stated on this stuff this past weekend.
null_zps2ee4dab7.jpg~original
This is how we mocked up the rear spring hangers
null_zpsfb4f9e86.jpg~original
null_zpsa769fba6.jpg~original
With springs in place set the shackle angle
null_zps9d7591be.jpg~original
null_zpsd43cb4e3.jpg~original
Here she is at droop
null_zps8da5e920.jpg~original
On to the front I will get some weld pics once there cleaned up a bit.
Front cam bolts came right out since I've aligned this rig after a few wheeling trips.
null_zpsd3d46d45.jpg~original
Than unbolted a few things and the front was free.
null_zps84e8631d.jpg~original
Anybody want a 4.88 diff
null_zps3ce0c772.jpg~original
And took plasma cutter to the brackets
null_zpse547f740.jpg~original
Here's some of the goodies going in to this rig
null_zpsd7002f89.jpg~original
null_zps576730ef.jpg~original
I built my shock mount and gussets
null_zpsc0395b0e.jpg~original
Shaved diff drain hole
null_zps2d77873b.jpg~original
Finished product ready for new seals
null_zps52c692c5.jpg~original
Very good work. It's always great to see a 4runner (or any older vehicle for that matter) get a second chance.
Whats with all the splatter left on the welds?
Looks good though! Excited to see this one come together. Hack that floor up! Haha
I'm using dual shielded wire .45 with mix gas so I'm thinking a lot has to do with my technique. My friend says I need solid wire but I'm not buying a roll for this big welder.
And yes the body lift will come off just have a lot to so with the gas tank, horse collar and tranny tunnel. So may not be till spring, need my truck back before winter. I usually dd it.
Rylan and I got some springs tore down for the ruf mix pack. Some original 48" main and secondary. Rest is from some 51" rears, and set of Downey springs.
IMG_7379_zps23ddb912.jpg~original
IMG_7374_zps8ff52293.jpg~original
IMG_7381_zps5f2f2de5.jpg~original
null_zps0dfa68d5.jpg~original
Final product has seven leafs one is anti wrap.
null_zps020f0522.jpg~original
Slowed the progress some do to some back pain lately. But got the frame almost completely ground down, also the front spring hanger area.
Need to plate the frame cant decide on just a section to seal up the motor mounts and shock hoop. Or from vin plate to front hanger.
I cut a piece of 3/16" down to fit in between spring hanger and front cross member.
Didn't really need this but dont like the gap most have with the hanger flush mounted.
Got the hanger in place and started bolting springs up
Let the weight of the rig on the springs to figure where frame tubes will be
Found the frame tube is right at the body mount.
Frame jig in place for proper angle of the tubes.
FYI frame has a few reinforcements to cut through
Found some mud must have found its way in the frame
just need a little cleaning up than tack and check the angles
On the axle housing, because I wheel lots of rocks. Have a friend in our club MO4wd, bashed the drain bolt loose. On the way home lost all the fluid and the destroyed the diff.
My awesome wife got me go pro. So I tried it out a bit.
got the frame tube holes cleaned up and aligned AND TACKED
Found some solid wire and got some decent welds finally
Bolted the springs in for shackle angle final tuning
its a little high at 52 degrees but after i remove a leaf it will be better
Started burning the hanger in place
Philthyphilthy
