toritochis
driveshaft installation....
The driveshaft length from the auto tranny. is different from the manual tranny. The auto driveshaft measures 58 3/4" from one end to the other or 52 3/8" not counting the sleeve yoke and the flange yoke. The manual driveshaft measures 61 5/8" from one end to the other or 55 1/8" I paid $100.00 for mine. The sleeve yoke on the auto tranny is wider in diameter than the auto; the auto being: 1.582" and the manual: 1.493" Take into consideration the rechroming of the sleeve yoke. I had to take it to a chrome plating shop since it was bleeding rust, I didn't want to risk the output seal going bad because of the rust. I had taken pictures of the sleeve yoke before the chrome plating but lost them along with a bunch of pictures I had set up for uploading later on. The shop charged me $30.00 for chrome plating it versus $106.00 plus S/H from the stealership. Here is the P/N for the sleeve yoke just in case you need to buy it: 37302-35030 I also replaced both front & rear u-joints. The front one was binding so I purchased both. I bought these from my local autozone for $19.25 ea lifetime warranty! If you prefer the genuine part, here is the p/n: 04371-30040 It costs around $70 bucks. A word of advise when replacing he u-joints.... clean the holes where the bearings go real well with scotch brite before installing, it'll make your life easier... don't oversize it just clean it. The hardware to install the rear portion of the driveshaft is the same as the auto.
