2000 LE - what is supposed to be illuminated?
rzgkane
Which of these switches and displays is supposed to be illuminated?
rzgkane-albums-2000+toyota+4runner-picture49562-2000-4runner-limited-climate-control.jpg
Im wondering if the power rear window switch and security/airbag areas should be back lit?
I'm also wondering if the power mirror switch should be back lit?
I'm feeling kinda dim.
LOL, none of the lights on my climate control light up, nor do any of the buttons work. There's a guy here who fixes them but I'm not sending mine out because I still need the heat. Only the 2 dials work. I'll take the manual controls in my 3RZ anyday over this crap.
You have the same setup as mine does, 99 Limited. I got the bulbs switched out finally also. on the ECT bar.
BTW - Scramble - the guy in NJ that fixes them does a great job and he's fast! Can't beat the price either. I think he's on this forum also ? less than 5 days to send and return all fixed up.
What lights up:
CCU LCD - Both sides - T4s
CCU Buttons Both sides - T3s
ECT DEFROST Rear window switches row - 2 bulbs T3s (from Toyota one is "tall" but with LEDS it lights them up no problem at regular height
The hazard button - T3
The cig lighter ring - #74
The ash tray - special bulb from Toyota
The key ring - #74
The glove box - #74
Auto shifter - #74
The drivers side door switch light up only on the driver side window. These are LEDS and very dim. The passenger side also lights up. I would be surprised if these were out.
This is the same on my 99 and 2000 Limited
Yes I am.
What lights up:
The key ring - #74
The glove box - #74
Auto shifter - #74
I know the #74, 24 and Neo3 but what is T3 and T4? where from - toyota?
I can vouch for this- He fixed mine including a cracked LCD screen for a great price and fast service. I snagged a dysfunctional unit from a pick and pull just so that I could have a little bit of heat while the unit was being fixed.
Yes I am.
Thanks Trex,
John lives about 20min from me so I'll be using his services in the spring when I can pull my unit out.
**yes, I just said pull my unit out**:bounce:
Thanks Trex,
20 minutes? You sure about that? I'm in S Jersey which is over an hour away from anywhere in NY.
Zynn
