2001-2002 t4r brake bleeding after master cyl change?
xspsi6
I have to swap out my skid control module which requires replacement of the entire master cyl but alldata has nothing other than a yota scan tool is needed but I know there is a way around that although I have found nothing in hours of googleing so this forum is my last hope.
You will need to bleed the system, if you breach the line. you will most likely end up with air in the line otherwise.
Bleed your brakes in order, if you still have air in the lines you can try vacuum bleeding or gravity bleeding from the master to the abs unit then to your brakes. Gravity bleeding is what worked for me.
Yes this is how to do it in a non hydro boost vehicle but 01-02 has a factory scan tool sequence to bleed the lines by opening and closing the lines remotely which is what I know there is a way around paying yota to bleed my brakes?
increasedc
