2002 4Runner Remote Starter Questions
I pretty much understand everything now. Thinking about it and researching a bit. Pretty straight forward. I just wondered about certain things. Like for instance, the bypass module has a certain color wire that should go to the remote starter, yet the same color for the remote starter goes to something else, and the remote starter wire that goes to the bypass is a different color. So I'm assuming that since they're two different manufacturers, that is quite common. Only other thing is, the bypass has wires that have to go to the ignition, and so do the remote starter, and a few other locations. Is it okay to tie the two together that have to be connected to the same wire, and hook it up? Or should I do separate locations for the wires from bypass and remote starter? If you need further clarification and can help, let me know!
TerryNap61
