2003 T4R amp/sub question
Frode222
Just bought my buddies amp/sub
alpine swr 1243d type R sub and a kenwood KAC9104d amp.
short question without details is: Can I install the amp/sub without taking out the current amp, and without replacing the deck? I know the setup only has 2 channels? going to the current amp, and from there splits to head to the amp.
Details:
I have the standard JBL audio system (no nav) with factory everything (as far as the sound system goes)
If I can get away without having to remove anything I would prefer it at this time, because I will be upgrading the rest of the speakers, maybe buying a navigation unit/deck combo after I get my tax return. Haven't fully decided, but I would like to get the sub up and running before then.
I've done electrical work on the car before, just new to the whole sound/stereo setup. I've already looked up wiring guides and such on these forums and they have been a big help! :thanks:
Does the amp have speaker level inputs?
If so, piece of cake. Mount everything where you want it, run your power, remote, and ground cables. Then pop the trim under the front seat belts and rear door sills. Splice into the factory speaker wiring and run your wires back from there.
I was the guy to go to in HS/College if you wanted your sound system installed. I just installed an Infinity setup in my '03 and the amp had speaker level inputs. This was my route and I will have a write up on my build thread soon. If you can't wait until then, shoot me a PM, I'll be happy do write up a quick set of instructions for you.
Wiring going into amp No sub specific, just tap into right+left?
Code:
FUNCTION PIN WIRE COLOR
Mute 1 WT/RD
Left - Input 2 GN
Left + Input 3 RD
Right - Input 4 WT
Right + Input 5 BK
Audio Signal Shield 6 BARE
TX - (Data Line) 7 WT
TX + (Data Line) 8 BK
Accessory 12 Volt 12 GY
Wiring leaving amp (I can't go from an amp to another amp can i? or just use a resistor or such to lower the output?)
Code:
Constant 12 Volt 25 BU/WT
Rear Pillar Spkrs + 26 GN/WT ¹
Center Spkr + 27 GN
L/R Door Spkr + 28 BK
R/R Door Spkr + 29 RD
Left Front Spkr + 30 PK ²
Right Front Spkr + 31 L.GN ²
Subwoofer Coil 1 + 32 BN
Subwoofer Coil 2 + 33 BU/BK
Constant 12 Volt 34 BU/WT
Rear Pillar Spkrs - 35 BN ¹
Center Spkr - 36 GN/BK
L/R Door Spkr - 37 YW
R/R Door Spkr - 38 WT
Chassis Ground 39 BN
Chassis Ground 40 BN
Left Front Spkr - 41 VT ²
Right Front Spkr - 42 BU ²
Subwoofer Coil 1 - 43 GN/WT
Subwoofer Coil 2 - 44 BU/RD
That info is from your factory amp.
With your new amp, you'll run power, gound, and remote (12v ignition source) to it.
Splice into each rear door wires (Red/White on the passenger side, Black/Yellow on the driver's side). The wires are a thicker gauge than the rest of the wires in the harness. Run these back to the respective amp inputs. You can use these speaker wires (even though they are amplified).
If you have a single sub, run Left + and Right - outputs to your sub.
delislerebecca
