bytemaster0
All of you with this issue, especially Jb50 (thanks for your detailed pictures!), I have a few vital questions as I tackle the 4Lo actuator in my '08 SR5 V6:
1. I'm assuming that the 4Lo actuator is identical in the V6 and the V8, as both have the same apparent design - one motor for the 4Lo. While I haven't actually opened up this part, I can hear the 4Lo motor running for 3-4 seconds. However, past this point, nothing happens - it never completes the shift into 4Lo.
Based on this, I'm assuming that the motor is not seized, as otherwise, I shouldn't be able to hear the motor running at all. Is this a correct assumption? After I shift back to 4Hi, I have to wait about 10 seconds, before attempting a 4Lo shift makes the motor run again. Once more, the motor makes noise as the actuator runs, but it doesn't shift.
2. Is there any possible way to open up the actuator housing without removing it from its location? I couldn't tell from your pictures how the actuator was located. Any insight into this is extremely helpful. Update: I just looked under the car and noticed that the "cover" screws are easily accessible - would it be possible to open up the actuator housing while it's still attached to the car, without having everything fall out? Is it somehow secured, in such a way that I could run the actuator, and then somehow "nudge" the gears to turn a bit farther as it does so? My seal seems to be perfectly okay, so I have no need to change it at this time.
3. If I loosen the bolts, will the seal keep oil from coming out of the transfer case? If I can hear the actuator moving, does the "hammer tap" method even make sense here?
Any help at all is greatly appreciated! Thanks!
