2005's actually have 330 ft/lbspeter78 said:Yes & No,
2004
235 HP
320 ft/lbs torque
2005
270HP
320 ft/lbs torque
2004
235 HP
320 ft/lbs torque
2005
270HP
320 ft/lbs torque
Northof49 said:2005 V8
Compression Ratio: 10:1
Horsepower (kW): 270 (201) @ 5400 rpm
Torque (N.m): 330 lb.ft. (447) @ 3400 rpm
2004 V8
Compression Ratio: 9.6:1
Horsepower (kW): 235 (175) @ 4800 rpm
Torque (N.m): 320 lb.ft. (434) @ 3400 rpm
As always, premium may be slightly better, particularily for things like towing, hills, hot days, or some combination of that, but it's made to run normally on 87oct.Pitbull said:Thanks, does the higher compression ratio require premium fuel in the 2005's? Based on the #'s I don't see how you could feel a 3% increase in torque and a horsepower increase in the 4800 - 5400 range??? I never drive my 4runner in that rpm range. I do drive my 350Z in that range but its a sports car:
Northof49 said:2005's actually have 330 ft/lbs![]()
Northof49 said:As always, premium may be slightly better, particularily for things like towing, hills, hot days, or some combination of that, but it's made to run normally on 87oct.
As for power differences, I'd like to say I notice just a hint more torque throughout the rev range, but it could be in my head. It's definetly a noticeable power jump in the higher rpms.....where the "old" V8 runs out of steam, the 05 keeps pulling progressively harder right to redline. So for, say, kickdown when passing, the new motor has noticeably more power, and a more linear delivery.
AlexJet said:Toyota recommends premium, but it's true, that for normal driving condition it goes with medium (89). I used to use premium (91), then switch to medium (89) for economical purposes, but had elevation of fuel consumption. So instead of paying 5c less for the fuel, I'm paying more for consumption, but altogether it become in savings approximately 1-2c per liter. Actually not a big deal, especially if you want to last your truck long.
Pitbull said:Do a search on this topic, its been beat to death. The concensus is that 87 works great and that the performance gain from 91 is very small. It premium does nothing to make your truck last any longer, and you don't save money with premium, it cost you more money. Don't waste your money on premium or midgrade, use regular. If you want to treat your rig right buy only www.toptiergas.com which is recommended by Toyota. Hope this helps.
Bumpin' Yota said:so with the 10:1 CR the 87 and 89 octane doesn't ping?
I'd be scared to death of my engine pinging on that stuff...a truck is a large investment, so paying an extra 30 cents a gallon to make sure the engine doesnt ping would be peace of mind i'd think...... But they dont seem to have that issue?
NOBumpin' Yota said:so with the 10:1 CR the 87 and 89 octane doesn't ping?
With 87 octane I've pulled a 3000 lb. load up 6,500 feet in 100 degree air with low humidity. All are a prescription for ping if it is to happen. Not a peep. (However, we'll see if that's still true when the larger trailer comes.)Bumpin' Yota said:so with the 10:1 CR the 87 and 89 octane doesn't ping?
