2Dogs said:
Hello All,
As mentioned in my other thread I need to find a replacement for my 2004 Limited
I can't get a straight answer for the following:
Can you get Nav and the center console CD changer in the 05? Had a dealer tell me no. I really liked this option and the controls on the wheel in the 04....
Thanks,
Dave
Allow me to give you a response.
From experience, you can have navigation installed (oemvalue.com - and in your case, you would purchase the OEM Toyota Solara unit), it has one slot for the Nav DVD and one slot for a single CD. I have a diagram that shows a Toyota 6 disc CD changer which is plug and play with the Nav unit, which is installed in the center arm rest section. It cuts off half of the bay, but that is where the diagram shows it being installed.
Now, your problem is that you most likely have the JBL 6 disc HU installed. You will need to swap out the large plastic center trim and the computer (mpg, outside temp, HVAC readout display unit), as it is housed in a plastic trim that is not compatible with the Nav unit. Many members have fabricated a surround, however, its not factory and I did not want the look. I did a swap with a member on this board - so by coincidence of close proximity and his need for a 6 disc JBL HU - our swap was done successfully.
Next step you would need to perform is getting the Voice Navigation feature to work. Technically, you would need to purchase part number 86150-0W050 ($312.33 shipped from Carson Toyota in LA) as you have the 86150-0W040. Along with running a shielded cable from pins 11, 12, 13 from the 20 pin SMALL plug in the back of the Nav unit to pins 22, 23 at the AMP (which will be the new 86150-0W050 Sub Woofer, Black Box Enclosure, AMP combo unit) to get a FACTORY Voice Navigation - otherwise, many members have added a small amp to an independent speaker which they have mounted in various locations. I personally do not want to do this - but many others have.
I hope this helps.
There is plenty of research on this very topic found within the search funtion
