phillyd2
Senior Member
Man that sucks. I had a copy of the instructions but I think I tossed them already, othewise I would have scanned them and emailed them to you.
It is pretty straight forward but there are two note worthy items that I do recall from the instructions.
1. Not all of the clips are the same size. If you line them all up there will be two that are longer then the rest. Those go on the front wheel wells on the lowest hole to the outside. Also when placing the clips make sure you put the side with the lip on the inside of the panel.
2. The holes you need to drill have to be 3/32 according to the instructions.
Also FYI the push pins for the rear are a pain, or at least they were for me.
Due to the rain I have only installed the two back ones and broke both pastic push pins. Anybody know the part number so I can order replacements.
And I did not notice that two clips are longer. Now I wonder if I used them on the back. Ugg.
