2011 4runner has poor traction on snowy roads
Tell that to Google... and Audi.... and Cadillac... and BMW... apparently they are doing away with that faulty poorly manufactured and highly suspect component you call "driver."
Like Airbus treats the "organic matter" in the cockpit.
Limiteds come with narrow, short sidewall (which equates to a stiff and minimal flex sidewall) tires.. so i'm not surprised that his 4 year old vehicle with probably half the tread left will have issues.. upgrade those tires to a better non oem set and you'll be just fine
I don't know the proper answer to the OP's question, but I don't believe anyone has really addressed it. The OP wanted to make sure he had the correct 4WD selection for snow/ice conditions. I know the Limiteds have AWD, but can someone in the know answer when is the proper time to lock in 4WD?
Don't lock the center differential if you're just cruising around in snow. If you do, you get 50/50 fr/r braking which isn't ideal.
That's because there's no black and white definitive guideline to when you should use 4HI. With the Limited's AWD you shouldn't need to use 4HI in most on-road situations. If you ran into an unplowed road with deeper snow then you might need to use 4HI or even 4LO if it's that deep. Honestly, if it did get to that point I might be more likely to just turn around and go home. Emergency crews are already going to be busy enough that they shouldn't have to come rescue someone in a 4x4 who thought they were invincible.
Lads, please, the OP is on to something: 4Runner has very poor traction in snow. After 30 inches, plus a little ice, it has to be put into 4H. And 4L is needed for the 40 inches, so, yeah, this is a real shortcoming.
Did you write that article? You sold me on the 4runner when I read that on Driving.ca, let Toyota know to send the commission your way.
[MENTION=85058]snobinge[/MENTION] There was a long thread not too long ago about the Torsen Center Differential and when it should be locked. You might find it informative to read through the entire thread - you'll learn there are no definitive answers, but plenty of informed opinions. The short answer might be this single post from that thread:
http://www.toyota-4runner.org/1845664-post45.html
The basics of a locked the Torsen center differential are clear: When locked, torque is divided 50/50 between the front and rear axles. The front and rear drive shafts rotate at the same speed. How these impact handling compared to an unlocked differential is a matter of debate.
Probably the best thing is to learn what your vehicle can and cannot do, then learn what you can and cannot do and live within those parameters.
Just remember this quote by Harry Callahan:
"A man must know his limitations"
:hiding:
Good to hear. And I put my money where my words are, as I bought the unit I was testing. Loved it too much to let go. Still do. I have the extreme good fortune of getting to drive whatever I want, from Lamborghinis to Jettas (this week, a Jetta TDI), and the ONE that stole my heart, and continues to do so, is the 4R Ltd. Doesn't hurt that there's a community of lunatics to share this with....:canada: :cheers:
yep just like you crazy canucks, only you folks would think of this :
Canadian city wants to install ice skating lanes
Indeed, we have the Rideau Canal, a 202-km marvel of waterway engineering in which 7.8 km is used for skating in winter. What else can you do in minus 20? We even make our own rinks (mine below), but more importantly, Canada was the birthplace of hockey, basketball, poutine and beavertails!
Just don't try to pet a beaver.
The two most important components of a vehicle:
1. Tires
2. Brakes
The two most poorly maintained components of a vehicle:
1. Tires
2. Brakes
I still cringe at every vehicle I see with horrid tires and or brakes. If you want to laugh, cry, be horrified, and lose all faith in humanity just look at the "What just rolled into my shop" sub-reddit. I'd say 2/3 of it is bad tires & brakes. What the hell is wrong with people?
Who do we talk to about having these faulty organic components recalled? There's too many defective ones in dangerous machines causing potential harm!
Where is the snow? :-(
I would loved to see some here in San Diego.....
Didn't you guys just get a couple inches in December! :becky:
Faith in Humanity = Lost
delislerebecca
