2015 led turn signal flasher?
:sniper:Has anyone switched out there turn signals for led ones? If so did you have to swith out the flasher fuse? Where is it located and which one did you purchase?
Hi Socal,
I know some of the guys here have swapped their stock bulbs for LED's, and no... you don't have to change fuses to accommodate the new bulbs; these will draw even less current than the stock bulbs do! Rgds
You will need something more than just the bulb or else they will hyperflash.
I understand that. I have the bulbs, but the OP is referring to the flasher to account for the hyperflashing. Just wondering how/where to replace and which one is required.
So i called the dealer and they said its under the dash on the drivers side, get on your back and its right under
Thanks. Have you had anytime to take a look? Was reading in some other threads that it was sealed in the ECU box and didn't seem like an easy mod. Trying to figure this out though, because I'd rather just do this than splicing in resistors.
My lady took the 4runner to work so when she gets home i will look, id rather not splice anything if i could just swap a fuse out.
I agree with that. Let me know what you find. I will try to look too tonight, but I get home pretty late, so you'll probably beat me to it.
Im stumped now, all i see are micro fuses and no big flasher fuse under the dash
[/URL]~original[/IMG]
I see a signal/hazard fuse but thats all i see in the engine bay
All the flasher uses are big though
https://www.superbrightleds.com/cat...nner--flashers+load+resistors/62-138--528376/
http://www.toyota-4runner.org/5th-gen-t4rs/77610-led-daytime-running-lights.html
Did some research on this last year and it seems like the flasher is integrated with the ecu in some form or fashion. Guys are using inline resistors to counteract the hyper flash since you can't swap out the flasher.
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/marker-lamp-load-resistor/191/832/
Having done LED on both my 5th gens I can tell you with certainty there is not flasher you can swap..
You simply splice a single resistor between neg and pos on each side and it works like oem.
Jesse1
