2015 TRD-P Suspension Triage
mcheslock
It keeps getting worse!
Kamalani Mahie was awesome enough to set me up with a replacement OEM spring to replace my broken one on the driver's side of my 2015 TRD-Pro.. But, as we got ready to put it on, we noticed that the spring perch on the strut is cracked all the way through!
Looking for advice on.. well everything...
a) Are the perches replaceable on these struts, and if so, any clue how I can track one down? (I've searched around without any success.)
b) If not, will a single 6112 strut work as a replacement (using the factory spring), and if so, what should I do about removing / bypassing XERAS? (Concerned I could be stuck replacing all the struts, which I reeeally don't want to do, as I don't expect to have this rig for much longer)
Thanks in advance for any ideas / suggestions / insight you can offer!
The spring perches should be replaceable, but finding a spare perch is going to be very difficult. To my knowledge the 6112 shocks are also only sold in pairs, so it is decision time. You're going to have to ditch the original OEM pro front suspension and replace it with either 6112s or some other strut package that replicates the pro lift.
I think you may be confusing XREAS with KDSS, but the Pro doesn't come with either of those systems so there should be no worry. If your ride does in fact have KDSS then it is not a factory Pro.
Rialm
