2019 Current phone mount solutions?
I've been looking for this too, and searched the board. It doesn't look like there are any solutions unless you're willing to drill, or want an on-dash/windshield mount.
i use a ram wedge in between my seats, and either a ram mount or one of those cheap chinese phone mounts on top of the ram wedge.
Nope, no cup holder mount, no seat wedge mount and certainly no mount that would bolt to your seat rail. Nope nothing out there.
The CD player mount was the best option for me. BOOM, instant carplay. The phone is right there, just pretend you installed one of those 1K units. Enjoy the back window down too.
I have a Pro Clip mounted to the center vent, with a iottie wireless charger off that. Solid and is great for charging either iPhones or Androids.
1. Proclip - Toyota 4Runner Center Dash Mount - ProClip Center Mount
Item: 854490 Toyota 4Runner Center Dash Mount #854490 | ProClip USA $29.99
2. iOttie Easy One Touch Wireless Qi Fast Charge Car Mount Kit || Fast Charge - https://www.amazon.com/gp/product/B0754NDNT8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1- $49.95
3. ARKON APGN-VSM Vehicle Specific Mount Adapter Plate Connects 4 Hole AMPS VSM to Garmin Nuvi 17mm - https://www.amazon.com/gp/product/B002ACP2FY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 - $14.40
And that's it. Works great. I just took the full mounting system from iottie off, and used only the wireless charging piece.
Proclip to the middle vent and i hooked a magnet to it, just toss the phone up there, very strong, person location. No drilling. Didnt use the little piece of 2 sided tape so I can move it around if I need to.
AWESOME. Thanks! Is it blocking a lot of the air flow from that vent? Once you have that initial mount on, you can put any holder onto it, correct?
It would have if I put it on the left side. I wanted to still get air flow to the driver, so I moved it to the right on the vent and it worked out well. Air still goes around it though.
Yes, any holder will work that works with the Proclip and that Ball.
RAM mount with adhesive base. Trimmed to fit the taper of the panel. Used this same setup in my 4th gen. Works well and that pad is stuck solid. I like my phone mounted here for easy use and no cables hanging while charging. I don't like drilling holes in my vehicles and avoid it when possible. Phone was definitely not worth a permanent hole.
Note: I angled it in such a way that it does not block my HVAC controls and I can still use that cup holder but usually don't.
cesZa-twrDTI2mUByjF7PvwGN_2E5EZhVYBq-lDL-31X_DXTsRuprxwaClgKNVG0BcO1MiXILsx3a4O6yy9k=w1919-h969-rw
2KpShYyzkv2ptwWZeKGUY1znkQ30e2A66r6lfiHlU6clmls7R5eUvbHuJo4_A253ybyj-mMLtvCQriLV3iMvuPaPCnMTnpm0dkPnEkJCg_2XL-kp9jJme9q8OwnZLzYN_XJEucwpJ7VMNg7BOlgYojKLA63YE3waeHhlXEMWmcFaJ-kNv62bDymiG-LE8HEe8-FLPi_AEAQHqvdi-iuHUhzGdlaCUHIFSd41fTco9UCFjth1hPLeaLIqI41mQLcETBaEKTj_U08GjqRZXbLU4JF5K4_QZ5fubyR2mCvi8oeB9XzKrJet_EZd4q4FRlRQOW2nNoLCdUWnenBpn2IHEm10lv9sku2xO6STqmFbLDs629wAOmGXiSAVdwgQ3la0Rjmzn7agsH6hJD-RKqg-FMa9QcG3JSPKdnCh6MHhZwfL4S56qztixn6MZ217oOLtFy0bAu8k-cYg-2Zzp-75hC3UrLza-gQ-9itz00wATQsLGBj1UdTl7Re6ipkrZjdrYo-xv3muIXIfgj2raOGb5mDmoSxxuGVXfRtuDsaYibc3E7ghvQmOlMnkK7EkI3AmSj93WUUY2OD98k4ERbr-utUFtswcTaFH_9jOYTc=w1919-h969
