265/75/16 tire. What size rim?
Mahalas
16x7
16x8
No significant difference.
Not sure if it matters but they will most likely be Duratracs.
I completely fail at making this a poll. :noidea:
I know the 16x8 will stick out more and that's why I would like to run them, but if there is a significant difference in off road performance with the 16x7 then I will settle for the factory rims.
Nevada - Can you elaborate as to why the 16x7 is better.
I have the factory rims on the same size duratracs. They don't stick out much:
I'm personally looking at getting 16x8 or 16x8.5 to get the wider stance.
16x8 they will stick out more
That depends entirely on the particular wheels offset. If the wheel being considered is a higher positive offset wheel than the original wheel, some or all of the added width could be inboard of the wheel centerline.
I'm mainly focusing on the rim width making a difference in the way the tire is seated and how it will be during airing down. Yes I know a skinny rim is the poor mans bead locker but is there such a huge difference between 7'' or 8'' wide when talking about a 265/75/16 tire.
unless having a 1'' wider stance has noticeable affects in handling.
pax at 4
