285 bfg ko2 with bilstein 5100
Mattd2
i was set on 275 ko2s, but now im leaning to 285s. they just look so much bigger. i have a bilstein 5100 set at 1.75 and NO spacer in the rear. will the 285s rub ? and if anyone has any pics of this setup with 285 ko2s i would greatly appreciate it. THanks in advance.
I put 275/70/r17 ko2 and they rubbed fender liner mod fixed it though. I have no lift mind you. Hears a close up shot
Probably
I have Toytec BOSS coilovers set to 2.5", and even with a fender liner mod, I still had to trim some body panels fore and aft in the front wheel wells. Still rubs in the back. Will need a body mount chop to get full relief.
If you are intending on keeping the lift at 1.75, you will experience some rub. Have you by chance thought about moving that spring seat up to gain some additional height? I saw a pic on this forum of a 14' with the 5100's clearing 285's.
I ran 285's on stock tires and suspension and had very little rub. Once I installed the lift + spacers a little more rub. Planning to take the spacers off and call it a day.
TerryNap61
