2in1 LED DRL Fogs
I have these on my 16 if you want to see pics. They are pretty nice. the only downfall is the switch for DRL is not the same illumination (green instead of blue) and the halo of leds doesn't illuminate when the fogs are on unless you turn the DRLS on. Since i don't use the DRLS its kind of a pain.
Thanks WhiskeyMikeTango. Would be great if you could post some pics. In your opinion, is the light output of the fogs better than stock OEM? Or is it on par with OEM but just a nicer LED setup?
<a href="http://s44.photobucket.com/user/HMCK20/media/IMG_4838_zps1ljdrmn5.jpg.html" target="_blank"><img src="http://i44.photobucket.com/albums/f49/HMCK20/IMG_4838_zps1ljdrmn5.jpg" border="0" alt=" photo IMG_4838_zps1ljdrmn5.jpg"/></a>
<a href="http://s44.photobucket.com/user/HMCK20/media/IMG_4839_zpsr0sb9mio.jpg.html" target="_blank"><img src="http://i44.photobucket.com/albums/f49/HMCK20/IMG_4839_zpsr0sb9mio.jpg" border="0" alt=" photo IMG_4839_zpsr0sb9mio.jpg"/></a>
DRL's
<a href="http://s44.photobucket.com/user/HMCK20/media/IMG_4840_zpsm8y0qmz4.jpg.html" target="_blank"><img src="http://i44.photobucket.com/albums/f49/HMCK20/IMG_4840_zpsm8y0qmz4.jpg" border="0" alt=" photo IMG_4840_zpsm8y0qmz4.jpg"/></a>
DRL's and Fogs
The light output is good enough. Nothing special. I don't have the OEM fogs to compare this with. I order my PRO with them. So i know no different lol
Baja designs fog lights
Will be coming out with a fog light kit for the 5th gen 4runners in about 1 month.To utilize the factory location for the fogs. They make some great products and to have an adapter bracket will be awesome! A great wide cornering amber will be good for the dusty desert at night and for snow.
Is there anyway to order these fog lights from the factory if so does somebody have an option code . They are not listed on Toyotas website
Dude... three different threads asking the same question? Do you not think the same people read the same threads? C'mon man.
Note to whoever : Dude if you're an idiot with no life , following people around to see how many posts they post in. Get a life . I never respond to negative hurtful people . I'm looking for positive input on trying to order these fog lights as some on these threads have said its so easy and they got it right from toyota so I'm posting in multiple threads because I can't get a response from those that say it's easy , only those that say you can't .
I was responding to a complaint from another member as I personally could care less. I do take moderating seriously though and if there is a complaint I follow up. You want to keep going?
Note to whoever : Dude if you're an idiot with no life , following people around to see how many posts they post in. Get a life . .
It's his job. He is a moderator in case you haven't noticed.
You have got to be the most thin-skinned person on this forum.
Will this Toyota kit #Part Number: 00016 - 48011 not work on a 2014 trail ? It says it's for a 2015-16 and will not fit a 2014. Anybody know if there is a difference between 2014 and 2015
The only reason I'm asking is the only difference I know of between the 2014 and the 15,16 models is that they got rid of the digital read out above the radio for the 15,16. They went with just a time read out. The Toyota # 00016-48011 says 2015-16 and is only $279 while the auera pt# t4r- 2n1 is $399 big difference in price but they look identical. I don't know if there is something else that changed between the 14-15 years that I don't know about. Thanks for any info guys.
2n1s cabin switch
[MENTION=113734]nydon[/MENTION], here it is
LED fogs on the wall
[MENTION=113429]RysiuM[/MENTION] LED fogs on the wall
Thank you so much. Looks very similar to Osram lights. I think Osram have a little more pronounced cut-off - the Osram projection looks more rectangular, but the shape and color is pretty much the same.
I took some a pictures from my on-board traffic camera showing my Osram lights for your comparison. First picture with only headlights on, then headlights together fog lights and the third one was photoshopped by getting the difference, which created the image of fogs projection only. Kind of.
Anyway the sides of fog projection is square making the projection almost perfect rectangular.
Looks pretty clean. one thing about toyota kit is it has LED DRLs built in - the reason I got them. Not sure about OSRAM kit.
erinobr2000
