3" smooth air intake mod
240m3srt
I built a 3" intake tube to replace the factory plastic piece with all the cumbersome boxes, as i didnt want to hack apart my factory intake tube for the ISR mod. I still havent had a chance to compare MPG's to stock but im hoping it helped a little. It definitely cleans up the looks of the engine bay. I recently ordered a full intake kit so i will no longer need this. Its for sale in the classified section. And if you want to build your own here is a link with some pics.
http://www.toyota-4runner.org/class...e/61468-3rd-gen-3-smooth-air-intake-tube.html
Very nice, wanna make another?:nerd:
Ha! Im thinkin' this is the only one ill ever make.
I bought the 45 degree bend and when it didnt fit i told my TIG welder "It probably just needs a cut or two"...2 hours later he was cursing me haha!:hatsoff:
Or..... you can find pipe like this and get the connectors for the same function that would be lot lighter
3" Aluminum Elbow Pipe/Air Intake/Intercooler 45dg bent: eBay Motors (item 380256270183 end time Sep-01-10 20:43:19 PDT)
Wont work without bending as its not an exact 45 degree angle thats needed.
FWIW, i still have mine available if anyones interested...willing to deal as its just taking up space. A lot less than Airaids $129 price tag, less than half:biggrin2:
Devils Advocate
Wouldn't it be alot simpler to just replace the the straight 6" piece ( that has the intake bladder attached )with a small tube, leaving the oem rubber bends and still look factory instead ?
Would there be a tangible gain with that welded pipe compared to leaving the oem joints, replacing the bladder/straight pipe?
If the goal is to lose the oem bladder, trying to maintain factory vaccum, and work with the original design it just makes more sense to merly remove the straight pipe/bladder and replace with a straight pipe ( you can paint black) and look like it was meant to be there.
Not to mention a 3" inch diameter Aluminum pipe you could get for less than $3 plus a $7 can of ceramic black paint.
Same as my TrueFlow
Bigtimeweb, how much of a difference has this made on your 4runner.. Thinking of smoothin the flow up on my 02...
044runner4
