30" LED Bar Behind Lower Grill
Bring this tread back to life.
http://im.toyota-4runner.org/attach...487-30-led-bar-behind-lower-grill-photo-4.jpg
Do you guys think we can mount the light bar on the lower part of the 06+ grill?
How about mount it on the grill/hood? I am afraid the mount will not be strong enough and will cause vibration.
The pic you posted is a 06+, so yes it will work in the lower grill just like mine. [MENTION=50591]gaterose[/MENTION] has had a double and now a single row 30" mounted on top of the front bumper.
I am sorry that worded my question wrong. I was asking to see that anyone has tried to mount the light behind the lower part of the hood grill (big grill).
I afraid the lower grill (small grill) too low for light output.
Ah....makes much better sense now. I don't see there being room in the factory grill to do this. Someone here did the satoshi grill and mounted a led bat behind it, although I can't recall who it was.
Thinking of trying this with 2 12" bars with space between them for my license plate. Any reason that wouldn't work?
Should work, but there will be some overlap based on my measurements. The grill is ~35" wide, but 2 12" bars plus the license plate (12") comes in at 36". I don't see where this would hurt anything, other than blocking a small amount of light.
Cool, thanks. I'd be ok with a bit of blockage, or I might live on the wild side and trim down my front plate a bit.
what size bolts did you use? Does anyone have measurements for the L brackets? Really thinking about doing this asap
It's been a while and I don't have it written down, so I'm not sure on the bolt size. I believe they were 1/4" x 2". I don't have measurements on the brackets, but could probably get some.
I would love to have them but i dont want you to go through any trouble for them. I think some cardboard will be my best friend as far as a template goes. How did you bend the brackets?
I just guessed on the bracket sizing. I knew they needed to be long enough to hit both sets of holes on the front crossmember, so made them an inch or two longer. I held the light bar and mount up there and mounted approx where the holes needed to be. To bend the brackets I put the strip in a vise and used a big hammer. Would have been easier/better with heat, but didn't have anything on hand to heat it with.
thanks for the help. this was a great idea and i hope mine turns out clean
One more question. What did you do about the foam in front of the crossmember
I don't want to jump onto anyone elses thread (don't want to offend you Ark) but you could also check out a few of my pictures to see a similar style for mounting a bracket for the bar. I ended up taking the actual steel bumper off and drilling right through to put the bolts on. The foam I think you're talking about is just sitting on there with pressure. remove when working and put it back on before you put the bumper cover back on.
The way I did mine though the bar sits further out then the way Ark has his so the grill would have to come out too.
[MENTION=105041]kakuno[/MENTION] I messaged you
Here's my version of this mod!
Instead of using a piece of angle iron across the entire bumper as my mounting point, I used the two pillars that support the bumper instead. Seemed easier, less modification, and less material to accomplish.
I also Satoshi'ed out the lower grill so that I could get as much light output as possible
Here it is fully assembled
Here it is with the lights fired up!
[MENTION=84223]JustSomeName[/MENTION] that looks awesome. Is that a 30" bar? Do you think a 35 would fit in there?
yes, but you'd have to use the design described in the OP. My mounts fits a 30" perfectly, won't fit any other sizes unless you added more pieces to it. The two bumper supports are exactly wide enough to fit a 30" bar, anything more or less would require a different mount
johnnya
