Urbanrunner716
You're gonna make some for 06-09 too right??? :naughty:
Good stuff. Mind sharing the design process? I'm curious how you got a baseline for the compound curves.
Oh ok, thanks. I've done the "picture next to a tape measure" method before, never thought about using a scanner. Seems like that would be relatively parallax free, no?For anything with fairly difficult curves, I typically start by scanning the object itself (in this case, the fog light assem.) on a standard office scanner. For any curves that can't be accurately scanned directly (too big of an object, uneven surfaces, etc.), I'll cut identical curves out of card-stock using the object as a 'stencil' and scan those in. Once I have all the scans I need, I just import them into Solidworks, scale/locate them based on the alignment/nominal measurements of the physical object, and trace the curves in. From there, surfaces and extrudes can be created and manipulated as needed.
TIN has a rear bumper pod, and let me tell you it is awesome. I have mine wited into my backup light,every time I back up at night, I smile.....
