3rd Gen Cylinder 6 Misfire HELP!
Pardon my inquiry but you first said you were going to replace the plugs this weekend and 2 minutes later reported that you replaced them. Are you a time traveler? Please don't take offense, but I pictured Sheldon of BBT typing your first comment as I read it....
Sorry about that. I just copied and pasted from a different place. I'm trying to get help with this issue, but on the Facebook page people haven't been very helpful.
No need to apologize. This site is easy pickins for Bots and you have to admit you sounded a bit like one. We are just normal humans here. I had a misfire recently and a new set of aftermarket injectors made everything right again. As a fallible human, I tried ALL the 'easy' stuff first. Not saying that's your issue. Have you cleaned your MAF?
Yes I did. Actually I already replaced the MAF sensor by an OEM.
Today the check light turned on again. I will check what the codes at the end of the day
Today just have 2 codes: P0300 and P0305.
When I installed the new cables and spark plugs, I moved the coils 1 cylinder forward : 1 to 3, 3 to 5 and 5 to 1. If I have a bad coil, is that possible the damage coil cause a misfire just in the cylinder 5 and not at cylinder 2?
Like in my case, I am leaning towards injectors. It seems to be our time. Pretty sure I was on the original set until recently (260k).
Yes the misfire will follow to the cylinder you moved the coil to, or it's companion cylinder. Had this on a 96. Miss in cylinder 5 but not 2. Moved coil to cylinder 1, it missefired on 1 but not 4.
Today something unexpected happened. I had a birthday party planned this Sunday, the place is 45 minutes from my house. Before the party, I went to Home Depot to return a rented equipment and didn’t noticed any misfire. During the 45 minutes trip, no misfire felt. After birthday party, when I was driving back home the check lights at panel spontaneously turned off! The car is driving smoothly again.
A day before, I filled up my tank at a different gas station (and put premium gas). I don’t know if if have something related, but probably had something at fuel injector causing the issue (??) and the different fuel clean it (??).
I planned swing by Toyota dealer tomorrow afternoon to buy a new replacement coil, but now I will wait a little bit more.
By the way, have any of you ever used those high mileage fuel treatments ?
Worth it? Helps clean injectors? Or the risk to damage something don’t make sense?
Yeah keep an eye on that misfire. As for fuel treatment I usually run the tech techron fuel injector cleaner. But also heard good things about the b&g 44k, but have not used it.
Quick update: misfire fixed!
After replaced the spark plugs and wires, still had a codes P0300, P0305, P0100 and P0110(before P0305 I had P0301, I moved the coil at cylinder 1 to cylinder 5 and the misfire code follow the bad coil).
I bought an OEM ignition coil and replaced, I had driven the past week and no codes showed anymore.
Next step is timing belt replace.
Thank you guys for the help
