Since installing the Shrockworks I haven't done anything really big with the T4R, but I have done a couple small projects over the past couple weeks...
1) Plati-dipped my emblems, license plate surround, and rear bumper. I'm really happy with how everything came out and I was considering doing my wheels too, but I like how they actually stand out more, so I'm going to leave them alone for now.
2) Rust prevention: I picked up a couple more cans of 3M Rubberized Undercoating and pretty much finished coating the rear end. It looks much better and so far everything I have done has held up really well.
3) Got an alignment - As many of you may or may not know, I swapped out my spacer lift for OME 882 coils a while ago, but never had it aligned because I wanted to get the bumper and winch on first and have it sitting at ride height. So, I took it to Goodyear and unfortunately they don't offer lifetime alignments, but I did get a 3 years for around $160, not too bad IMO.
Up next...
4) Even after getting an alignment, I am still leaning to the driver side a bit (both front and rear). So, I ordered a 1/4" top plate spacer for the front (
Front Top Plate Spacer (One - 1/4") - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits) and a 10mm coil spacer for the rear (
Rear Coil spring spacers 10MM - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits). The plan is to install the rear coil spacer first and drive it around a bit to see if it helps to level out the front. If not, then I'll install the top plate spacer on the front.
5) Timing belt: I finally pulled the trigger and ordered a timing belt kit. I went with this kit from aircabinman on eBay based on a couple timing belt-related threads:
Toyota Timing Belt Water Pump Kit Genuine Parts 4 Runner Truck 3 4L V6 | eBay. It's more expensive than most other kits I've seen, but it comes with ALL OEM replacement parts which is well worth the extra cost IMO.
6) License plate mount: Here in VA we are required to have both a front and rear license plate, super annoying!. But, since I am running a synthetic line and hawse fairlead for my winch, I don't have anywhere to mount my license plate so I just have it taped to the inside of my windshield...I talked to Mark at Shrockworks and they actually just came out with a solution a couple weeks ago: A flip up license plate mount (
Flip Up License Plate Mount). "Our new flip up license plate mount bolts on with the top two winch mounting bolts and hangs down covering the winch opening. When you need to use your winch, simply flip up the your license plate and go." So I ordered one in bare steel and I'm planning on painting it with the Duplicolor red Metalcast that I used on the fairlead and Hella light rings.
