4R Trek 268 - Valley of Three Hills
Ron4RNevada
150205 – 4R Trek 268 – Three Hills Valley in the Hot Springs Range.
This is the shortest and quickest of the five treks since I exchanged the ’04 Land Rover for the ’13 4Runner SR5. I had a few hours to kill this morning and as it is supposed to rain tomorrow I decided to go for it.
As most of you know; Fernley is at the western edge of the Fortymile Desert in northern Nevada. About three miles east of my place is the southern edge of the Hot Springs Range. The range is about 25 miles long south to north and about 10 miles wide east to west. It is a geothermal area with quite a few commercial geothermal wells throughout the range.
The rock is mostly andesite and basalt lavas. 12000 years ago this desert and all of the mountain range below 4400 feet in elevation was under a pleistocene lake covering about 8800 square miles. Once the lake dried up all of the silt and sand on the bottom has been blowing all over the place filling up all of the nooks and crannies of the mountain. So what we wind up with is a young volcanic mountain range with a lot of very fine sand covering the low spot on the leeward sides.
Anyhow, today’s trek was driving three miles on the pavement to Black Butte, then putting the truck into 4 wheel drive and exploring a little rift valley I like to call Valley of the Three Hills because it has three volcanic cinder cones running along the center of it. I drove about twelve miles in 4wd most of it in low range. Then I drove the three miles back home. 18 miles total in about three hours. Enjoy the pics.
26801-Blk%20Btte%20and%20Lt%20Btte_zpsol9fqv8e.jpg~original
26802-Hot%20Sprgs%20Rng_zpspvxvpchg.jpg~original
26803-Into%20the%20valley_zpszqh88oik.jpg~original
26804-Across%20rise_zpsvbpfsxgj.jpg~original
26805-looks%20low_zpsslxdv7ub.jpg~original
26806-rocks%20and%20sand_zpsfd909gne.jpg~original
26807-A-Trac%20works%20good_zpsq98uyihb.jpg~original
26808-Three%20Hills%20Valley_zpsixwgs8tb.jpg~original
26809-Sand_zpst8pvabta.jpg~original
26810-Poseur_zps2i7bx7nz.jpg~original
26811-Sand%20drifts_zpsnyccyhqi.jpg~original
26812-Three%20Hills_zpsi3s04sqc.jpg~original
26813-Steep%20Saddle_zpsv5jp9no3.jpg~original
26814-LO-2_zpsnbcnxcsu.jpg~original
26815-Wash_zpsbzkoqi0t.jpg~original
26816-Thass%20All%20Folks_zpsbvtzltt8.jpg~original
THASS ALL FOLKS!
By the way: For 99% of trails in northern Nevada a stock SR5 gets the job done - As long as you equip it with some E-Rated (10 ply) aggressive tires.
You don't need a Trail Edition or a locked rear diff or KDSS or a lift or special shocks or light bars or extra skid plates or rock sliders or special wheels or steel bumpers or even a winch - - -
That other 1% of trail will need something entirely different than a 4Runner SR5....
Good stuff. Why drive in low range though? I'm sure there are tough places but in your pictures it looks like most of that can be driven in 2WD. I know back here I just use 2WD on dirt roads and even some hills.
Mostly its about going slow enough..... Through the rocks I stay in low range and manual shift the gears; not having to touch the brakes at all. In sand sort of the same thing; if its really soft the brakes will bury you when it gets a bit firmer you can shift up; if there have been motorcycles tearing up the trail and making moguls its easier handling them.
Pretty much the whole day is spent at about 5 miles per hour so going into 4HI or 2HI doesn't gain you anything.
With the Land Rover you were always in 4 wheel drive - just locking and unlocking the center diff when required.
hard for folks who have never been here to understand how slow you have to go in our high desert country. Rocks lurking along the trail just waiting to blow your sidewall, sometimes can take 2 hours to go a couple of miles cuz you are driving from rock to rock. And when it gets wet if you wander off the road and break through the "crust" you be stuck. I have to laugh when I see the maxtraks, they sure beat all the pieces of plywood I used to carry in the truck to help get unstuck. Great pics, miss the desert now that I live over on the wet side of Oregon, thanks for sharing.
patnewton
