Thank you very much for this write-up. It's been years since I did my lift & I've forgotten a lot of it; your write-up will be very helpful.
I'm confused about one part:
"Also, make sure the Lower Control Arm is supported by a jack. The weight of the vehicle needs to be on the UCA for the bushings to seat properly. If you tighten the UCA through bolt without weight on the suspension, the bushings will be destroyed quickly. You can torque the through bolt with the wheel on the ground, and the weight on the tire."
Does this mean that you only partially tighten the through bolt until you've got the wheel(s) back on & jack stands removed? I didn't see that as part of the last step.
If you support the LCA's with a jack are you raising them up or just keeping them at the level they were before the old UCA's were removed?
Thanks again for taking the extra time to post the pics & write-up.
