If you don't want wheel spacers and a lift, then don't put them on. It's as simple as that.If somebody was looking to do a lift without wheel spacers, what options are out there now? I know you can get wheels with correct backspacing, but are there other things to consider?
It might be a good idea to update this post. The original sticky is years old and there is a lot more useful information out there now.
Missing vendors:
Radflo , King , Fox , Bilstein 6125s , etc...
The part about the sway bar relocation kit / diff drop has caused a lot of people to order extras as most vendors ship them with the kit now. Just something you might point out as many people I talk to use this sticky as the end all to ordering there 1st lift kits.
Toytec Superflex Springs actually give 3" lift not 2" and the HDs are 4"
* Should know I've installed 30+ of these springs now
Might throw a part in about shock body size.
( rough idea )
1.5" is good for stock
2.0 for a bumper and skids
2.5 once you get into winches heavier bumpers skids etc...
example an ultimate kit on bilstein 5100s is not going to last a year with a heavy bumper ( some ive seen exceed 150 lbs ) , 12000 lb winch , Skids , roof top tent , etc.. It will over heat and burn up. I couldn't find a good link to share explaining this better sorry. I also don't know if a heavier spring would make up the difference.
I'm running 265/70-17 without a lift. Minor, minor rubbing at full lock or full flex. No trimming was done, I still have my mudflaps. Tires are Cooper Discoverer A/T3.What can i install as a complete lift to give me 2/1 so I can get 265/70r17 under the truck? I have looked at the toytec/bilstein 5100 lift but that gives 3/2 (and you're saying 3/4 here). I don't want to jump to a 275/70r17 tire, tires are $60 more each for the extra size. What should I be looking at?
Would like to replace fronts and rears for a better ride and a slightly bigger tire.
For a short lift, either get the spacers or check out the OME low lift - see here: http://www.sleeoffroad.com/products/4runner_suspension.htm
Some threads on the subject (haven't read them):
http://www.toyota-4runner.org/4th-gen-t4rs/194010-low-lift-slee.html
http://www.toyota-4runner.org/4th-g...ut-replacing-ucas-slee-off-road-low-lift.html
Same here. Running 265/70/17 With no lift. Hankook dynapro atm tires. The only rubbing I HAD was in the passenger side front wheel well. Trimmed off the little bubble in the fender liner that was covering a mounting bolt for the washer reservoir. No more rubbing.
Exact tire I want. Thank you.
Oneluv summed it up good. Get the Bilsteins from Down South Motorsports, will be $335 if I remember correctly. Order a 1.5" daystar spacer for the rear and pick that thing up a little.
Oh, from one father of teens to another, make him help! Let him learn how to do that stuff so that when he gets it he can do it himself. Also, if you are going to be looking at new tires go with something that has a more aggressive look. Some wheel spacers or rims that push the tires out an inch will help greatly too. Don't let him talk you into big rims, they ride like shit and will get bent up offroad if you guys ever do that. And never underestimate the power of plastidip! You can change the whole look with that stuff and when you don't like it anymore pull it right off. I've even done interior pieces in mine with it. You can also paint over plastidip and still pull it off later.
Looks like you have the front and rear selected on the first item, then rears again in the second.Man, looks like the price went waaay up??
any other places?
Again, This would be for a 2003 4runner -SR5 2 wheel drive
Well that makes sense now. Didn't see that part. Good deal.
So with the mood coil springs and the shocks, will I need anything else? Sorry, just dont know squat about this and trusting yall suggestions.
Struts? Hell, i barley even know what they are. Are they installed with the shocks.
This is stock 03 with 265/70 R17's just installed. Was sisters car and never changed shocks or anything. So above is what I want to order. Anything else I need? Sorry again for all these questions, I don't know squat about this. Thanks guys.
Lifting wont cause rubbing.Will it cause any issues with rubbing etc? If not, then spacers are mostly for aesthetics?
