5th Gen 4runner: will my tires (285’s) rub? Here are some things to consider...
285/65/18 Ko2's
Volk Te37 18x9 +0
Stock height
No rubbing at full lock.
Did the "fender mod" aka trim the front bumper // mudflap.
I'm looking to combine an Icon lift...
WHEEL & TIRE FITMENT INFO:
OEM Wheels & Tires: Yes
Aftermarket Wheels: 8-8.5" Wide, 4.75" Backspace
Aftermarket Tires: 33" x 11.25
(Larger Tires May Fit but Fender Trimming and Modifications will be Required)
...with these wheels (w/ 285/70/17 BFG KO2s):
TRD 17" Forged Aluminum Alloy Single Wheel (PTR45-35010)
17”x7.5”x 6mm of + offset
3.98 inch back spacing
Will the backspacing on the wheel be an issue here?
Does anyone know where the tire size chart went? For some reason it is not showing up in the thread and I have checked on my computer and cell phone... so I don't think it is me. Maybe the links are broken?
If anyone has it saved and could re-post it, it would be greatly appreciated.
Thank you!
Thank you!
Looking to replace my tires soon. Is anyone running the Nitto Ridge Grappler in the 285/70R17 116Q? Model No. 217710. Are you happy with them?
This is an SL load tire, from what I can tell, and it is much lighter than the C load model. Looking to install on my stock Pro and it looks like it's in the yellow area as far as the fitment chart is concerned.
I have 2016 4runner SR5. I want to put on 285/70/17 tires probably K02. I have TRD pro rims. They want to do a 2 1/4 inch level in the front only and said that would work for the 285s. I'm concerned it won't be enough. Should I do 3 inch front and back lift and would that work for 285s?
2003 4runner
On my stock 2003 sr5 RWD 4runner, with a Bilstein 5100s set to 1.75” in the front. And a 1” rear spacer. With running boards and mud flaps removed what’s the biggest tire I can fit without rubbing or trimming. And if stock is the biggest what’s the biggest with very little/easy trimming?
Ambrose67
