5th Gen Aluminum Roof Rack Using OEM Siderails: NiseRack
Hey Jason! Sent you a pm. Disregard the 3 bracket comment. After reading through this thread again I think the 4 rail set up looks pretty sweet. I'm ready to order a set of the brackets so shoot me a text and we'll work out the details.
Thanks again!
Also, I'm back in town from the latest hurricane scare. If you are wondering why I "get out of Dodge" at the drop of a hat it's because there are really only a six roads out of New Orleans and all but one of them is a really long bridge.
I have a place to go not too far away and I'd rather leave than get stuck here. I travelled through New Orleans after Katrina and it looked worse than you think it did based on what you saw. If you are still here when something like that happens you are pretty much stuck as you saw during Katrina. I don't want my family to go through that so I jet outta here when it gets interesting.
All of this in combination with getting my house ready to sell cuts into my development time considerably. Sorry for all the delays.
Has anyone tried the LFD Offroad wind fairing. Was wondering if it would work on the excellent NiseRack. Mounted mine yesterday and it is fantastic. Noise is negligible up to around 65-70. 70-80 and it's definitely there. Not unlivable but I would love to try a fairing to see if it made any difference.
[MENTION=176262]Eitek1[/MENTION] good to hear you are back safe and sound!
These brackets look pretty slick and I'll definitely be picking up a set. I'm up in Canada so shipping is always a PITA so I might hold off until the faring is available. Any ETA?
Haha, I've built a lot of stuff out of 80/20, and I don't think I've ever managed to get all my slide-in connectors inserted without having to disassemble part of my project after forgetting them! The roll-in connectors solve the problem most of the time but some of the special connectors have to slide in.
FWIW, if you put the one cutout on either the left or right side, you'd have access to the front slot from one side of the rig, and access to the back from the other, although perhaps the desire for symmetry outweighs having access to two slots.
This is a great design BTW, I've been window shopping rack solutions for a while and this is looking like it might be the best fit for my needs.
To add some additional capability for light duty mounting of items I used your idea of “roll-in” slot connectors to attach eye bolts to the top of the rack.
Parts:
- 80/20 Inc, 3670, 10 Series 1/4-20 Roll in T-Nut with with Ball Spring (10 Pack)
- US Stainless Steel 316 1/4" Lifting Eye Bolt 1/4" UNC Marine Grade Qty 4
- M6 or 1/4 inch flat washers
- 1/4in-20 jam nuts Qty 4
You can slide them anywhere you want in the track, and you can remove them. The jam nuts allow you to adjust the position and snug down the bolt. I would not use this for strapping down really heavy items, but it’s good enough for attaching things like tarps or traction boards.
I thought I'd post an "action shot". I don't own a truck and needed to move a 22 foot extension ladder. It was a non-issue with the NiseRack and a two ratchet straps. I did learn something though, on the interstate the wind resonates through the ladder and sounds exactly like a dial tone.
Can you tell me what the hight off the rails is to the top of the bars, i looked through the posts, but did not see it , thanks in advance.
Just placed an order. Any time frame on a fairing?
Crash tried to send you a private message. For some reason I can’t. I’m out of town so your order will ship Monday.
I’m still working on a faring. Sorry it’s taking so long... I’m trying to sell my house and move to a place better suited to my hobbies. That and my day job are taking all my time it seems. I need about 2 full days to finish and I think I’ll get those soon.
Sounds good. No worries as I know life gets in the way. Thanks for the response
Maybe I missed it in this thread, but is there an option for Black powdercoating?
The powder coating option would be expensive and wouldn’t really add any value. Powder coating is typically done on metals that are at risk of corrosion. The alloy used in the brackets is a corrosion resistant aluminum alloy. Basically powder coating would be “wasted” in this application.
If you want black brackets, just paint them black. Unless you are remarkably rough you won’t damage the rattle can finish. My first “test” rack was in use for a year with no issue. The only place the paint was “damaged” was at the mating surfaces between the bracket and the crossbar. This was only visible once I took the rack apart.
Sounds good, thanks! Yeah I saw the black ones on the website but didn't realize they were rattlecan jobs.
Love the look and design of these crossbars — very nice work. One question I had was, are they higher than the antenna fin? In other words, for example, would a load of lumber sitting on the bars clear the fin?
Another question: if I wanted spray the hardware black, what’s the best paint to use?
alexaturner
