5th Gen. KDSS vs. Non-KDSS handling performance & sway bar diameter differences.
All I want to know is that if I buy one without kdss, is it going to be easier to lift and will I have more flexibility with options on lifts?
Sent from my HTC U11 using Tapatalk
I installed a Dobinson lift front and rear, springs, shocks and the Treaty Oak KDSS extensions. I'm a medium skilled mechanic, watched a ton of you tube videos. Was pretty easy, the piston side of the KDSS is the easy side the fixed side you will need to lower, worst part is backing out the bolts, they will be corroded (mine is a 2021). If you can change springs you can do a KDSS lift
charlesz
