5th gen T4R
blubee
hey.. guys...
i have 2010 4runner trail w/kdss...
i'm trying to get 17x9 6on5.5 -12 offset w/35 tires...
do you think it fits ??
i also have 2inch front wheel spacer and 1.5inch rear wheel spacer....
3inch lifted and will change UCA and lift front coil about 3inch more...
real coil will installed with 2.5inch coil spacer...
i know if i do that i have to get longer break line and change rear sway bar...
would you do it??
Lol 35s are not going to fit. At all.
You'd be lucky to get 285/75s to fit with that much offset and never mind using those wheel spacers.
You cannot change the sway bars out without removal of the entire KDSS system. Extended brake lines are not needed as the stock suspension design does not articulate that much
And you can't lift more than a 3" lift in the front without using a huge drop bracket, and if you want to do that I suggest you leave the forum now before you feel the wrath of everyone on here calling you names
Thundro
