91 4runner tow package
whodatdur
i got a 91 4runner, and i need to replace the headgasket since it just failed, and im going to replace the water pump, timing belt and so forth, and apparently there are 2 versions of the water pump, one for a apparent tow package and one with out?, how do i tell which one i am in need of and so forth thanks :D
There is a coolant line that runs from the water pump to the driver's side of the engine in to something a little bigger than a can of soup. That is the oil cooler.
You can see it just to the right of the engine mount. The hose runs under the mount to the water pump.
IMG_20131206_222257_673_zps5c7c9c6f.jpg~original
ghengiskhan
