96 4runner maf upgrade to 99+ maf wiring
kingin
So I'm fighting the p0171 cel I've replaced the front 02 sensor with new denso unit, replaced spark plugs and wires checked for vac leaks, cleaned maf twice with maf cleaner, cleaned iacv valve, cleaned throttle body, ran fuel inj cleaner through gas tank, swapped a used junkyard maf. And I still have this p0171 code hahahha truck drives fine just want to fix the issue.
My 4runner is a 1996 with the expensive Maf sensor so instead of dropping 350+ for a new one id rather pay 100-150 for a 99+ mafs if it can be made to work. Thanks
P0171 code fixed. I had a leak from the intake manifold upper replaced gaskets code went away but still had kinda hard starting issues. Code also came on while driving and would go away then come back. Replaced fuel pump last week and so far no code and better starting. Fingers crossed so far so good.
allcarhistory
