99' 3RD Gen Limited 2WD 7500$ Long Beach, CA
Suprareal
2001 Toyota 4Runner Limited
V6 Automatic
Clean title in hand ready to be signed over
70K Miles on the engine replacement
Odometer shows 243K
Currently registered until Feb 2020
Passes smog flawlessly
I am selling simply because I’ve outgrown the 4runner and need to get into a full size pickup truck.
I personally replaced the engine 10K miles ago with a low mileage imported engine from LA JDM (receipt in hand). These imported motors normally have around 60K when shipped over from japan.
The engine is immaculate. You’re not likely to find another 4runner of this caliber under the hood when it comes to cleanliness & healthiness. I replaced every single seal and gasket before it was installed. There are no leaks and no old residue of past leaks.
Timing belt and components all replaced with OEM new at this time as well
You are more than welcome to bring your own mechanic to go over the car.
Maintenance always done on time using synthetics.
AC recently overhauled and blows cold flawlessly
Suspension Lift: 3” rear 2” front
Front icon adjustable coil overs
Front total chaos tubular control arms
Rear land cruiser 7 wrap springs
Rear old man emu shocks
Wheels & Brakes:
04 Tundra oem wheels
04 Tundra front caliper (red powder coated) upgrade
04 Tundra drilled front rotors
Rear drum brakes recently changed
BF Goodrich all terrain tires 285/75/16 still like new
NEW parts recently installed:
Denso radiator
Denso ac condenser
Denso ac dryer
Starter
OEM O2 Sensor
Energy suspension steering rack bushings
The rest:
Satoshi grill mod
Catalytic converter lock
Custom trailer hitch with wiring made by Defworx
Transmission cooler
Wade in channel window visors ( rear not pictured but included)
NGK spark plug wires
Kenwood stereo head unit
Aftermarket speakers all around
JBL tweaters
MTX Amp
MTX jackhammer dual 12” subs
OEM rear 4runner floor mat
Goodyear floor mats
Cons:
Driver’s seat is torn
Hood is OEM Toyota but not originally from this car. The paint color is a slight off from the rest of the car.
delislerebecca
