994runner build
all right so if anyone in Canada is interested i got my hatch and carrier from these guys its a 2 man show but there awesome to deal with!! there in BC
Rocky Mountain Imports Ltd.
Toll Free Phone: 1-800-921-4536
Phone: (250) 656-6024
Fax: (250) 656-6025
Email: [email protected]
RMI / JDM parts .net - Canada's #1 source for JDM parts - The lowest prices and BIGGEST selection!
What did it cost for the hatch & carrier, if you don't mind me asking. I really want to do this at some point. Are they able to find one the same color as your 4runner?
The parts and shipping just came around 750 and the hatch was originally blue but I bet they can find one in japan the same color it just would take a lot longer to get mine was in BC and it took only a week to get
What kind of rims are those?
PROCOMP 7036 17x9
And thanks fo all the likes guys!!
Wow that was some amount of work to be done to fit that carrier.. but the end result is what really matters. People oughta know how nice these Surf hatch and tire carrier truly is, how they are purposely built for our vehicles to start with....You're rig is one of a kind 4Runner indeed.
Congrats on a successful Hilux Surf mod!
Thanks mang i really want to get my 4runner up there
how well has your Hilux Surf tire carrier been holding up so far?
and what size wheel/tire are you carrying on there?
Alright here is a lil bit of my rack light build still not finished but getting there first of all imma thank redsonja (james) for all the welding!!
since i will never shorten my rack i decided to have it welded together
IMG-20130108-00712.jpg~original
IMG-20130108-00713.jpg~original
flexingout023.jpg~original
flexingout027.jpg~original
flexingout035.jpg~original
flexingout037.jpg~original
flexingout041.jpg~original
after alot of grinding and sanding it was time to prime it and get her ready for paint i was not too picky about it being perfect
IMG-20130115-00727.jpg~original
IMG-20130115-00731.jpg~original
IMG-20130115-00730.jpg~original
IMG-20130115-00726.jpg~original
while i had the primer drying i went out and bought some L bracket cut them up and paint aswell
IMG-20130117-00736.jpg~original
IMG-20130117-00738.jpg~original
IMG-20130117-00739.jpg~original
next was to paint the whole rack before i just used a scotch brite pad and scuffed the surface so the paint will be all even and not original rola black and the new flat black the paint i used was a flat black by tremclad hopefully it will with stand alot of abuse
IMG-20130115-00733.jpg~original
IMG-20130115-00734.jpg~original
as you can see i just re used the old mounts
IMG-20130117-00741.jpg~original
IMG-20130117-00742.jpg~original
IMG-20130117-00740.jpg~original
IMG-20130117-00743.jpg~original
Now it is the part i will hate the most is doing a wiring harness the front bar will be controlled by a switch same with the side ones and the rear i was just thinking to wire it up to the reverse lights that's the only time i will ever use them
cut off my old rattled muffler and installed a new Dynomax Thrush glasspack muffler sounds soo much better ill post some vids of the sound later on!! i just have it clamped on for now too see if i like the sound
Picture001-2.jpg~original
Picture002-2.jpg~original
Picture003-2.jpg~original
alright so more pictures to go about my led roofrack i was tempted to drill thru the roof but i decided not too so i just had the wirees go thru the rear hatch!!
100_4751_zpse75262b5.jpg~original
100_4753_zps8c348a2b.jpg~original
100_4754_zpsde9dbc83.jpg~original
100_4756_zps9780bf29.jpg~original
100_4757_zps06a1394b.jpg~original
100_4758_zps6f6c9e08.jpg~original
and in this next pictures you can see how i hva my wires all hidden sorta
100_4759_zpsff3ff442.jpg~original
100_4760_zps607ef02a.jpg~original
and as for my wireing to the batteries i just tucked it under the trim
100_4764_zpsc06c4c93.jpg~original
100_4766_zpsd5040372.jpg~original
100_4768_zps4f259915.jpg~original
100_4772_zps04a1a8f4.jpg~original
As for the realys i did not want to have millions of wires running up to the front so all i did has use some double sided tape and tape it behind the plastic trim i think it turned out very nice
100_4775_zps778dce39.jpg~original
100_4776_zps116f387e.jpg~original
now it was time to tidy up the wireing on the roof rack
100_4779_zpsfa1d9436.jpg~original
i added a few more zipties after this picture
100_4781_zps5f629459.jpg~original
if you guys are wonderin on any size demension for your mount i made a pre cut on cardboard an that one zigzag line is where i have the bend
100_4788_zps56984f59.jpg~original
and now my bluesae fuse box bracket and mounting this here took some time due to the hood i had to close re alighn the fuse box and breaker so it will not hit the hood
100_4787_zps9565abc7.jpg~original
i decide to go with welding cable 2ga as it is VERY nice to work with and not hard and stiff like battery cables i just cut and soldered my own tips works like a charm.
100_4790_zps85023b3d.jpg~original
100_4791_zpsf0da43b9.jpg~original
100_4792_zpsb1292523.jpg~original
And the finished product of the whole install on the mount
100_4793_zpsa1299958.jpg~original
100_4794_zpsb752007c.jpg~original
All my light switches I <3 BRIGHT LIGHTS!!!!
100_4796_zpsfe57514b.jpg~original
here is a shot of my front led bar off and on in the dark without headlights
100_4815_zps35324d03.jpg~original
100_4814_zps9fbce3f9.jpg~original
Hey Martin, Great build so far. Saw you have the bushwackers. They seem to look good on the runner. I'm thinking of doing some myself but haven't seen many people with them. I have the same SR5 chrome flares you had. Whats the width difference between the two sets? Were they pretty easy to install?
Thanks guys. And as for the. USB wackier they were super easy to install the only thing I did diffrent than what the manual said was for the rear doors to drill into ,I just used double sided tape and it is still holding up from 3 years ago. The measurements are a lot I believe the old SR5 ones were only 1" and these bushwhacked ones are 3".
CoaterZ_FL
