Hello all!
First, just to give you guys some history, I replaced my A/c system about 6 months ago. I had the system drained. Then, I replaced the drier and compressor, o-rings, brought it back to pep boys, and had it leak checked and refilled with freon. Also, at that time, had belts replaced. The compressor was supposedly new (AC Delco replacement) bought off of EBay. It's a 1997 3.4.
Problem:
It's been running fine for 6 months- but now, the compressor only engages occasionally. It seems that when it engages, it only does so reliably for a few days, then will stop engaging for a while.. I replaced the fuse, rewired the compressor, and still no luck. Any ideas? The A/C light is green (not flasing or anything) but the clutch will not engage.
I thought also that the R134a might be low (which, as i understand will cause the clutch NOT to engage) but how does one check the pressure if the system is not running? When it's not engaged, the sight glass shows no dye..
HELP!
Problem:
HELP!
