Abs pump motor failure, any trusted places to buy replacement?
Eugene13
Good evening all, I have a 2007 4Runner v6 Sport and I am having the ABS Pressure alarm fiasco happening. Dug into it and found the electric motor under the brake master cylinder is shot, (armature worn out and exercise wear on brushes) and I believe this is the issue. Don’t wish to buy a whole new master cylinder assembly for $2k+, anyone replace this specific part and have a recommendation where to purchase from? I’ve seen places that rebuild them but when taking it apart I broke a few plastic tabs in the housing, so that not an option. Thanks in advance
I'm pretty sure all the rebuild service sites only need your old one as a core, so I think if you reassemble it they will take it, I don't know of any where else to get a replacement motor other than to buy a new OEM one....but unfortunately it can only be purchased with the motor and pump assembly together and costs around $1200
Thank you, going to call Eurton Electric tomorrow as they're local to me here in SoCal, I here they specialize in this.
Worst case scenario I think is that they don't accept your old motor for the core and charge you a bit more.
I purchased the pump assembly (47070-60050 ) that includes the accumulator, pump and electric motor for $728 from the Toyota dealer. Piece of mind to replace everything although I had them install it for me. So it was a little expensive.
